PonokoExtruderAssemblyBOM
Revision as of 17:15, 8 December 2008 by RussNelson (talk | contribs) (version migrated from twiki)
  1 0.1uF capacitor
  1 200-300mm of nichrome wire with a resistance of about 8 ohms
  1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre
  1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle
  2 680Z "sk8er b0y" bearing
  5 M3 20mm screw
  2 M3 30mm screw
  4 M3 40mm screw
  3 M3 50mm screw
 11 M3 nut
 23 M3 washer
  2 M5 25mm screw
  5 M5 30mm screw
  4 M5 nut
  1 M5 nyloc nut
  3 M5 washer
  1 M6 32mm o/d washer
  2 M6 dome nut
  2 M6 half- or press-nut
  2 M6 washer
  4 M8 nut
  1 M8 studding 110mm
  4 M8 washer
  1 PTFE tape
  2 hole socket strip
  4 large M3 washer
  1 m5 washer
  4 small, stout springs
  1 thick, solid, insulated copper wire
-- Main.RussNelson - 08 Dec 2008
