PonokoBOM
This Bill of Materials is complete for the instructions that have been written. More parts WILL be needed as more instructions are added. I may have made mistakes, however. This page is automatically generated. Do not edit it. If you think you need to edit it, or have found a mistake, contact RussNelson. This BoM? is best for locating parts needed for a particular assembly. For procuring parts, Zach's parts lister at http://parts.reprap.org/ is best, but I have to figure out how to import this into it.
There are links to show changes at the bottom of the page. I've been changing the BOM in the last several days; here is a link to the BOM that existed before that: http://reprap.org/bin/rdiff/Main/PonokoBOM?rev1=1.8&rev2=1.3
- 1 PonokoBedChainFitting
- 2 PonokoCornerAssembly
- 3 PonokoExtruderAssembly
- 4 PonokoExtruderSocketAssembly
- 5 PonokoFrameBaseAssembly
- 6 PonokoFrameBracing
- 7 PonokoOptoEndstops
- 8 PonokoRepRap
- 9 PonokoRepRapXAxisAssembly
- 10 PonokoRepRapXMotorAssembly
- 11 PonokoUpperCornerAssembly
- 12 PonokoXAxisAssembly
- 13 PonokoXIdlerAssembly
- 14 PonokoYAxisAssembly
- 15 PonokoYInstallation
- 16 PonokoZAxisTensioner
- 17 PonokoZFrameAssembly
- 18 PonokoZMotorAssembly
- 19 all
1 2200mm of 4.5mm ball chain 3 8mm i/d compression spring approximately 16mm long 12 M3 25mm screw 12 M3 nut 24 M3 washer 3 M8 25mm screw 6 M8 nut 9 M8 washer
24 4.5mm BBs ifthrust 3 608Z skate bearing ifskate 24 M3 25mm screw 24 M3 nut 48 M3 washer 6 M8 washer ifthrust
1 0.1uF capacitor 1 200-300mm of nichrome wire with a resistance of about 8 ohms 1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre 1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle 2 608Z skate bearing 1 625ZZNSK bearing 5 M3 20mm screw 2 M3 30mm screw 4 M3 40mm screw 3 M3 50mm screw 11 M3 nut 23 M3 washer 2 M5 25mm screw 5 M5 30mm screw 4 M5 nut 1 M5 nyloc nut 4 M5 washer 1 M6 32mm o/d washer 2 M6 dome nut 2 M6 half- or press-nut 2 M6 washer 4 M8 nut 1 M8 studding 110mm 4 M8 washer 1 PTFE tape 1 gear motor 2 hole socket strip 4 large M3 washer 4 small, stout springs 1 thick, solid, insulated copper wire
4 M3 16mm screw 2 M3 25mm screw 6 M3 nut 8 M3 washer 8 M5 30mm screw 6 M5 nut 2 M5 nyloc nut 16 M5 washer
4 8mm diameter 500mm long bright steel rod 12 M3 40mm screw 12 M3 nut 24 M3 washer 4 M8 400mm studding 16 M8 nut 8 M8 washer
PonokoFrameBracing
20 M3 25mm screw 20 M3 nut 40 M3 washer 8 M8 600mm studding 2 M8 650mm studding 40 M8 nut 40 M8 washer
PonokoOptoEndstops
6 M3 25mm screw 6 M3 nut 6 M3 washer 2 M5 16mm screw 2 M5 nut
PonokoRepRap
2 1200mm 3.5mm (#6) ball chain 1 1200mm of 3.5mm ball chain 4 8mm diameter 500mm long bright steel rod 3 M3 25mm screw 3 M3 nut 6 M3 washer 4 M5 50mm screw 2 M5 8mm grub screw 10 M5 nut 8 M5 washer 1 M8 half-nut 1 M8 nut 1 M8 washer
4 M3 12mm screw 4 M3 16mm screw 4 M3 20mm screw 16 M3 25mm screw ifNEMA17 2 M3 40mm screw 12 M3 nut 16 M3 nut ifNEMA17 22 M3 washer 32 M3 washer ifNEMA17 4 M5 25mm screw ifNEMA23 4 M5 nut ifNEMA23 8 M5 washer ifNEMA23
32 4.5mm BBs ifthrust 4 608Z skate bearing ifskate 32 M3 25mm screw 32 M3 nut 64 M3 washer 8 M8 washer ifthrust
PonokoXAxisAssembly
17 M3 16mm screw 1 M3 20mm screw 19 M3 nut 22 M3 washer
1 608Z skate bearing 4 M3 12mm screw 4 M3 16mm screw 12 M3 20mm screw 8 M3 25mm screw 2 M3 40mm screw 24 M3 nut 46 M3 washer 1 M8 80mm studding 5 M8 nut 3 M8 washer 2 M8 wide aka fender washer
PonokoYAxisAssembly
4 608Z skate bearing 8 M3 30mm screw 8 M3 nut 12 M3 washer 1 M8 500mm studding 2 M8 70mm bolt ifbolt 2 M8 70mm studding ifstudding 8 M8 nut 2 M8 nut ifstudding 2 M8 nyloc nut 12 M8 washer
PonokoYInstallation
4 80mm long 8mm diameter steel 8 M5 8mm grub screw 8 M5 nut
2 5mm i/d soft plastic tubing, approx 22mm long 4 M3 12mm screw 5 M3 25mm screw 10 M3 nut 14 M3 washer 2 M5 nut 2 M5 screw 4 M5 washer
8 8mm diameter 500mm long bright steel rod 8 M5 8mm grub screw 10 M5 grub screw 17 M5 nut 1 M8 half-nut 11 M8 nut 2 M8 washer
8 M3 25mm screw 3 M3 30mm screw 14 M3 nut 25 M3 washer 4 M5 25mm screw 1 M5 8mm grub screw 5 M5 nut 4 M5 washer
all
1 0.1uF capacitor 2 1200mm 3.5mm (#6) ball chain 1 1200mm of 3.5mm ball chain 1 200-300mm of nichrome wire with a resistance of about 8 ohms 1 2200mm of 4.5mm ball chain 1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre 56 4.5mm BBs ifthrust 1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle 2 5mm i/d soft plastic tubing, approx 22mm long 7 608Z skate bearing 7 608Z skate bearing ifskate 1 625ZZNSK bearing 4 80mm long 8mm diameter steel 16 8mm diameter 500mm long bright steel rod 3 8mm i/d compression spring approximately 16mm long 12 M3 12mm screw 29 M3 16mm screw 22 M3 20mm screw 120 M3 25mm screw 16 M3 25mm screw ifNEMA17 13 M3 30mm screw 20 M3 40mm screw 3 M3 50mm screw 213 M3 nut 16 M3 nut ifNEMA17 384 M3 washer 32 M3 washer ifNEMA17 2 M5 16mm screw 6 M5 25mm screw 4 M5 25mm screw ifNEMA23 13 M5 30mm screw 4 M5 50mm screw 19 M5 8mm grub screw 10 M5 grub screw 54 M5 nut 4 M5 nut ifNEMA23 3 M5 nyloc nut 2 M5 screw 36 M5 washer 8 M5 washer ifNEMA23 1 M6 32mm o/d washer 2 M6 dome nut 2 M6 half- or press-nut 2 M6 washer 3 M8 25mm screw 4 M8 400mm studding 1 M8 500mm studding 8 M8 600mm studding 2 M8 650mm studding 2 M8 70mm bolt ifbolt 2 M8 70mm studding ifstudding 1 M8 80mm studding 2 M8 half-nut 91 M8 nut 2 M8 nut ifstudding 2 M8 nyloc nut 1 M8 studding 110mm 79 M8 washer 14 M8 washer ifthrust 2 M8 wide aka fender washer 1 PTFE tape 1 gear motor 2 hole socket strip 4 large M3 washer 4 small, stout springs 1 thick, solid, insulated copper wire
-- Main.RussNelson - 03 Jan 2009
