PonokoBOM
Revision as of 20:37, 30 December 2008 by RussNelson (talk | contribs) (version migrated from twiki)
This Bill of Materials is complete for the instructions that have been written. More parts WILL be needed as more instructions are added. I may have made mistakes, however. This page is automatically generated. Do not edit it. If you think you need to edit it, or have found a mistake, contact RussNelson. This BoM? is best for locating parts needed for a particular assembly. For procuring parts, Zach's parts lister at http://parts.reprap.org/ is best, but I have to figure out how to import this into it.
Changes from the previous BOM to this one: http://reprap.org/bin/rdiff/Main/PonokoBOM?rev1=1.54&rev2=1.3
- 1 PonokoBedChainFitting
- 2 PonokoCornerAssembly
- 3 PonokoExtruderAssembly
- 4 PonokoExtruderSocketAssembly
- 5 PonokoFrameBaseAssembly
- 6 PonokoFrameBracing
- 7 PonokoRepRap
- 8 PonokoRepRapXAxisAssembly
- 9 PonokoRepRapXMotorAssembly
- 10 PonokoUpperCornerAssembly
- 11 PonokoXAxisAssembly
- 12 PonokoXIdlerAssembly
- 13 PonokoYAxisAssembly
- 14 PonokoYInstallation
- 15 PonokoZAxisTensioner
- 16 PonokoZFrameAssembly
- 17 PonokoZMotorAssembly
- 18 all
1 2200mm of 4.5mm ball chain 3 8mm i/d compression spring approximately 16mm long 12 M3 25mm screw 12 M3 nut 24 M3 washer 3 M8 25mm screw 6 M8 nut 9 M8 washer
24 M3 25mm screw 24 M3 nut 48 M3 washer
1 0.1uF capacitor 1 200-300mm of nichrome wire with a resistance of about 8 ohms 1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre 1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle 2 608Z skate bearing 1 625ZZNSK bearing 5 M3 20mm screw 2 M3 30mm screw 4 M3 40mm screw 3 M3 50mm screw 11 M3 nut 23 M3 washer 2 M5 25mm screw 5 M5 30mm screw 4 M5 nut 1 M5 nyloc nut 4 M5 washer 1 M6 32mm o/d washer 2 M6 dome nut 2 M6 half- or press-nut 2 M6 washer 4 M8 nut 1 M8 studding 110mm 4 M8 washer 1 PTFE tape 1 gear motor 2 hole socket strip 4 large M3 washer 4 small, stout springs 1 thick, solid, insulated copper wire
4 M3 16mm screw 2 M3 25mm screw 6 M3 nut 8 M3 washer 8 M5 30mm screw 6 M5 nut 2 M5 nyloc nut 16 M5 washer
4 8mm diameter 500mm long bright steel rod 12 M3 40mm screw 12 M3 nut 24 M3 washer 4 M8 400mm studding 16 M8 nut 8 M8 washer
PonokoFrameBracing
20 M3 25mm screw 20 M3 nut 40 M3 washer 8 M8 600mm studding 2 M8 650mm studding 40 M8 nut 40 M8 washer
PonokoRepRap
3 1200mm of 3.5mm ball chain 4 8mm diameter 500mm long bright steel rod 3 M3 25mm screw 3 M3 nut 6 M3 washer 4 M5 50mm screw 2 M5 8mm grub screw 10 M5 nut 8 M5 washer 1 M8 half-nut 1 M8 nut 1 M8 washer
4 M3 12mm screw 4 M3 16mm screw 4 M3 20mm screw 16 M3 25mm screw NEMA17 2 M3 40mm screw 12 M3 nut 16 M3 nut NEMA17 22 M3 washer 32 M3 washer NEMA17 4 M5 25mm screw NEMA23 4 M5 nut NEMA23 8 M5 washer NEMA23
32 M3 25mm screw 32 M3 nut 64 M3 washer
PonokoXAxisAssembly
17 M3 16mm screw 1 M3 20mm screw 19 M3 nut 22 M3 washer
1 608Z skate bearing 4 M3 12mm screw 4 M3 16mm screw 12 M3 20mm screw 8 M3 25mm screw 2 M3 40mm screw 24 M3 nut 46 M3 washer 1 M8 80mm studding 5 M8 nut 3 M8 washer 2 M8 wide aka fender washer
PonokoYAxisAssembly
4 608Z skate bearing 8 M3 30mm screw 8 M3 nut 12 M3 washer 1 M8 500mm studding 2 M8 70mm bolt ifbolt 2 M8 70mm studding ifstudding 8 M8 nut 2 M8 nut ifstudding 2 M8 nyloc nut 12 M8 washer
PonokoYInstallation
8 M5 8mm grub screw 8 M5 nut
4 M3 12mm screw 5 M3 20mm screw 9 M3 nut 14 M3 washer 2 M5 ?mm screw 4 M5 washer 2 nut
8 8mm diameter 500mm long bright steel rod 8 M5 8mm grub screw 10 M5 grub screw 17 M5 nut 1 M8 half-nut 11 M8 nut 2 M8 washer
8 M3 25mm screw 3 M3 30mm screw 14 M3 nut 25 M3 washer 4 M5 25mm screw 1 M5 8mm grub screw 5 M5 nut 4 M5 washer
all
1 0.1uF capacitor 3 1200mm of 3.5mm ball chain 1 200-300mm of nichrome wire with a resistance of about 8 ohms 1 2200mm of 4.5mm ball chain 1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre 1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle 7 608Z skate bearing 1 625ZZNSK bearing 16 8mm diameter 500mm long bright steel rod 3 8mm i/d compression spring approximately 16mm long 12 M3 12mm screw 29 M3 16mm screw 27 M3 20mm screw 109 M3 25mm screw 16 M3 25mm screw NEMA17 13 M3 30mm screw 20 M3 40mm screw 3 M3 50mm screw 206 M3 nut 16 M3 nut NEMA17 378 M3 washer 32 M3 washer NEMA17 6 M5 25mm screw 4 M5 25mm screw NEMA23 13 M5 30mm screw 4 M5 50mm screw 19 M5 8mm grub screw 2 M5 ?mm screw 10 M5 grub screw 50 M5 nut 4 M5 nut NEMA23 3 M5 nyloc nut 36 M5 washer 8 M5 washer NEMA23 1 M6 32mm o/d washer 2 M6 dome nut 2 M6 half- or press-nut 2 M6 washer 3 M8 25mm screw 4 M8 400mm studding 1 M8 500mm studding 8 M8 600mm studding 2 M8 650mm studding 2 M8 70mm bolt ifbolt 2 M8 70mm studding ifstudding 1 M8 80mm studding 2 M8 half-nut 91 M8 nut 2 M8 nut ifstudding 2 M8 nyloc nut 1 M8 studding 110mm 79 M8 washer 2 M8 wide aka fender washer 1 PTFE tape 1 gear motor 2 hole socket strip 4 large M3 washer 2 nut 4 small, stout springs 1 thick, solid, insulated copper wire
-- Main.RussNelson - 31 Dec 2008
