PCB Heatbed/Aluminium Bed Mount Plate/Borosilicate glass
Revision as of 06:19, 14 May 2016 by Fp (talk | contribs) (How to buy)
PCB heat bed
The Prusa designed PCB heat bed is a great addition to your Reprap printer to help your printing platform to be a heated surface perfect for minimizing warping of larger prints.The heating element is on the bottom side. The heating is done by long traces of copper.The top side is solid copper to keep the PCB flat enough.
Borosilicate glass
If you want to make your printing platform flat enough, ideal stuff is glass sheet. Borosilicate glass is rated for higher temperatures than normal sheet glass making it a better material for use as a heated bed. After cracking a few sheets of normal glass from rapidly cooling or heating, borosilicate glass will quell your frustrations.
Aluminium Plate
The Aluminium Bed Mount Plate design is pre-drilled and tapped to mount boltable bushings, the PCB heated print bed, belt standoffs, belt clamps. This mount plate is designed to fit onto a Reprap Prusa Mendel lm8uu 3D printer.
Round PCB heatbed for Delta Rostock mini
Round PCB heatbed is the new product of Geeetech. The heatbed improves print quality, especially when printing ABS by reducing thermal warping. The diameter of the total heatbed is 215mm, and the diameter of the active heated area is 200mm. It’s as the width as 1.6mm. The allow temperature is from room temperature to 120°C. The heatbed can take both 12V and 24V input and the power is 144W. Moreover, it only takes 4 minutes to heat up the heatbed to 110°C.
How to buy
Borosilicate glass sheets are available from several suppliers:
3D printer set-MK2,Aluminium Bed Mount Plate,Borosilicate glass
Alfa-Tech3D: MK2B, Borosilicate glass in Several sizes and shapes, Delivered Worldwide
Lulzbot: borosilicate glass bed sheet.
Airwolf3D: borosilicate glass plate (214 mm x 200 mm).
Airwolf3D: borosilicate glass plate (214 mm x 307 mm x 3mm).
McMaster-Carr: borosilicate glass sheets in many sizes and thicknesses up to 3/4 inch thick. (suggested by Wanhao USA).
Voxel Factory: Custom cut borosilicate glass for any 3D Printer supplies custom borosilicate glass sheets 3.3mm thick in any size.
Cincinnati Gasket & Industrial Glass: Borosilicate Glass apparently supplies custom borosilicate glass sheets in any size.
