PCB Heatbed
Revision as of 23:20, 12 January 2014 by 3DBob (talk | contribs) (USA)
PCB Heatbed
PCB Heatbed
unknown
[[1]]
WARNING
"WARNING!!! Be aware from where you buying the PCB heatbeds!! There is one critical thing, the heatbed must be etched directly from 35um copper clad! ASK YOUR SELLER!!! If the board is plated, as it's normally done, no manufacturer can guarantee the final thickness of copper or how even the copper is around the board. Which means that the final power wont be evenly distributed around the board or the board wont have high enough output generally.
Main warning sign are plated holes! Plating of holes requires copper plating.
About
PCB Heatbed MK1 is developed by Josef Průša
  • 200 mm x 200 mm active heated area
  • 209 mm center-to-center mounting holes (outside the active area).
  • 214 mm x 214 mm total PCB size
I was working on this idea for nearly six months, inspired by neufeld.newton.ks.us/electronics/?p=864 .
Where to get it
The .brd file is available here: [[2]]
Mechanical drawings for designing mounting plates/etc (if desired) are here: [[3]]
(Please note that I dont get any provision from these :-)) Manufactured PCBs can be found here:
Asia
RobotDigg
Reprap Austria http://www.reprap.cc
3D Acessories Hub (IN ,Worldwide) http://www.3dacessorieshub.com
Reprapdiscount Hong Kong and Worldwide
Botech Circuits China and Worldwide
Makemendel
3D Printer Czar Hong Kong
He3D
EU
3Distributed (UK, Worldwide) http://www.3distributed.com/collections/electronics
RepRap.me (Denmark, Worldwide) http://reprap.me/PCB-Heatbed-MK2 (Two color ruler design MK2 heatbed and MK3 ALU-Heatbed)
Menextech (Spain, Worldwide) http://www.menextech.com/shop
Charlie's 3D Technologies (Belgium, Worldwide) http://www.charlies3dtechnologies.eu/
GADGETS3D (Poland, Worldwide) http://gadgets3d.com/index.php?route=product/product&product_id=68
RepRapSource (Germany) http://www.reprapsource.com/en/shop/show/6403
eMotion Tech (France) http://www.reprap-france.com/lit-chauffant-et-accessoires/10-pcb-heatbed.html
Cubic Print (Germany) http://www.cubic-print.com/PCB-heated-bed
LHPPortugal(Portugal) http://www.lhpportugal.com/loja/index.php?route=product/product&product_id=193
Paoparts (France) http://www.paoparts.com/fr/200-plaque-chauffante-mk2a.html
Robots3D (Russia, Worldwide) http://robots3d.ru/parts_accessories/heated_beds/heatbed_mk2a_pcb.html
uw3Dprinter.nl -ONLY MK2-(Netherlands, Worldwide) http://www.uw3dprinter.nl/en/heatbed-mk2.html
USA
MakerGear
Lulzbot
Ultimachine
MakerFarm
RepRap-USA
3D Printer Czar-USA
Printing
Cover the bed with kapton tape. Degrease it and print.
ABS temp: 110°C PLA temp: 50-60°C
MAKE SURE YOUR PSU HAS 10 MORE AMPS SPARE!!!
Mounting
Known working solution, I (prusajr) use is Glass sheet (3mm) with glued on cork standoffs and on top of that is glued the heatbed. http://www.flickr.com/photos/prusajr/5410919911/ http://www.flickr.com/photos/prusajr/5410919707/
When mounted only using the four corners, the inherent warp of the pcb can be a problem, hence it is better to use the cork mounting system above (as the piece of cork in the centre helps to keep the pcb flat). Magnets can be used in replace of the cork, this makes the bed removable. However, I (mooneyj) have only tried this on a darwin type printer (where the build platform only moves in z). During fast printing, the darwin vibrates and it seems the heatbed magnets slide over each other slightly. The acceleration of the y axis on a mendel may cause the magnets to slide also. Perhaps a hybrid of magnet and bolt mounting would work well?.
The current standard, however, is to simply place the glass on top of the heatbed, and affix it on the four sides with bulldog clips. The clips will not melt under pressure, and sufficiently hold the glass to the bed. This makes removal more easily for cleaning as well.
Note: According to the Eagle file posted on Thingiverse, the M3 holes are spaced 209 mm
Mechanical drawings are here: [[4]]
Sides
PCB Bed has two sides, one with the traces (bottom side) and one with silkscreen (top).
Printing on top side is safer, works great.
Printing on bottom is more effective and heats up quicker. (Though the LED, resistor and wire connections are liable to collision with the print head. Also the tracks could be damaged if the print head collides. Make sure your z-bed-springs are not too strong to prevent damage during a collision).
Connection
Optional LEDs
The LEDs are optional, but if you choose to use the LEDs you MUST install the resistor.
'Parts'
2 x Surface Mount LEDs
1 x 1K ohm Surface Mount Resistor
Mount the LEDs in different directions (polarity) so that one of the LEDs will light up regardless of the board's polarity. You can use a single LED if you are certain of the polarity.
Electronics
RAMPS
See RAMPS1.4, RAMPS1.3, or RAMPS1.2 depending on your version.
Sanguinolou The MK2 PCB heatbed heats up to 110C when powered through the heated bed connection on Sanguinolou, your power supply should be 300W and ensure your wires from your power supply to the Sanguinololu should be capable of handling the total draw of 20A+. Using a 300W ATX power supply with the 4wire ATX dual 12V connector is working well for me.
N.B. It is recommended that you use a heatsink on your heated bed mosfet, it will get hot!
N.B. It is recommended that you measure the resistance of your board. I (evilB) didn't and blew up my Ramps 1.2 MOSFET because of a too high current. My measured resistance was 0.8 Ohm.
Testing
Its now in working state, Printed load of kits on it, working great.
Main Idea is to use resistance of pcb traces as heating element.
The following video shows a PCB heatbed MK2 being heated to 60 degrees as seen by an infrared camera: <videoflash>QE90bDUaAno</videoflash>
Thermal insulation
It's a good idea to insulate the underside of the heatbed in order to get a faster heat up time and a overall better thermal performance.
The MK2 / MK3 Thermal Insulator is a great way to do exactly that.
Mount the gasket firmly under the heatbed for the best thermal isolation.
It fits the standard heatbed size of the 214mm x 214mm (200mm x 200mm) MK2 and MK3.
Material: Cork
Thickness: 2mm
Where to get it
www.RepRap.me
FORKS (not done by Prusa)
MK2, MK2a
It's not successor of MK1 even with it's name. It's concurrent design. - Josef Prusa
MK2a Heatbed with minor changes by Tony Lock
About the MK2a
I liked Josef's original design but wanted to be able to use through hole components, have the thermistor poke through the middle and for it to look good on the 'back' with the silkscreen that Josef designed on that side as well.
The MK2a has a few further changes:
  • A mounting hole in the middle of one edge to allow for easier bed leveling thanks to Nophead for this suggestion.
  • Larger LED and Resistor pads to allow for 1206 size surface mount components.
  • Much larger area to solder the current carrying wire, easily connect ribbon cable (such as with the Mendel90 headbed connection). Also the through holes increased in size.
  • The redundant pads on the non-heating element side of the board removed to prevent confusion. These are not electrically connected if the board is not plated (plated boards are bad for the reasons outlined by Josef Prusa above).
Where to get it
The MK2 .brd file is available here: File:PCB heatedbed Mk2.brd
The MK2a .brd file is available here File:PCB heatedbed Mk2a.brd
Manufactured MK2 PCBs can be found here:
eMotion Tech - Fully soldered and wired
http://www.3distributed.com/products/mk2-heated-bed-1
www.gadgets3d.com
www.RepRap.me
Botech Circuits MK2a
eBay MK2a
eMakerShop MK2a
Reprapdiscount MK2 and MK2a eBay
Paoparts (fr) MK2a
Uw3Dprinter.nl MK2 (NL,BE,DE,FR)
www.reprap.cn
Printing
MK2
Although you can print directly to the bed covered in polyimide tape, no PCB is perfectly flat. It is recommended that you follow the directions in mounting, below, for better results.
Mounting
MK2
The MK2 board can be mounted either side up and is designed to be mounted as Josef describes:
http://josefprusa.cz/pcb-heatbed-final-mounting-and-wiring-solutio
The holes in the 4 corners to attach the heated bed MK2 to the top print plate are not suitable for M3 bolts though! Use M2.5 instead.
The glass protects the tracks from a head crash and is easily swapped out.
The board dimensions are identical to the MK1 design.
Insulation between the board and the thick plate should improve heat-up times and reduce energy consumption. An example is here:
http://reprap.org/wiki/Mendel_heated_bed#Thermal_Insulation
Caution, I have not tried this with the temperatures that the PCB bed can reach!
MK2a
The MK2a has a central mounting hole on the front side to allow for three point mounting. This is much easier for bed leveling in comparison to 4 point mounting. First level the side with two holes and fix in place, then level the side with one hole. A glass plate is highly recommended to provide a truly flat surface and rigidity.
Sides
MK2
The PCB still has a side with the traces on and a side without but now the silkscreen is on both the top and bottom, this makes it look good even when 'upside down' under a layer of glass. The LED, resistor and power wires can be mounted on either side of the board, with either surface mount or through hole components. If you are using through hole be careful when soldering not to interfere with the glass and introduce a gap between the glass and the PCB. If the MK2 board is made properly without copper plating then be sure to only solder the LED and resistor to the same side and the tracks. This problem is solved in the MK2a by removing the pads on the non connected side.
There is a central hole in the board and it is sized so a small thermistor (for example the EPCOS one: http://uk.farnell.com/jsp/search/productdetail.jsp?CMP=i-ddd7-00001003&sku=3878697 ) will fit though it allowing contact directly with the glass. todo: test efficacy of using heat sink compound to better thermally couple the thermistor to the glass
Connection
Polarity doesn't affect the PCB, however the LEDs have a polarity.
MK2
There are pads and un-plated through holes for connecting the power wires. Ensure that the wire you use is thick enough for 10A, and solder it to the pads on the track side of the PCB. It is a good idea to think about strain relief so your moving build platform does not flex the joint, this can lead to failure of the joint over time. I recommend routing the wire from the heated bed to strain relief on the thick sheet before routing it to your controller/power supply. todo: get pictures of strain relief
MK2a
The pads to solder onto have been greatly increased as shown in the picture below. The picture shows the wires prepared for soldering routed through the holes for extra security. This does not remove the need to use proper strain relief.
MK2b Dual Power
As you can see in the pictures below depending on the voltage you want to use you have to use different solder pads, but it's written on the PCB which pads have to be used for which voltage.
Optional LEDs
MK2
The LEDs are optional, but if you choose to use the LEDs you MUST install the resistor. Solder the components to the pads on the track side of the PCB. With the MK2, conventional wired parts can be substituted for the surface mount parts. If your MK2 board is made properly without copper plating then be sure to only solder the LED and resistor to the same side and the tracks. This problem is solved in the MK2a by removing the pads on the non connected side.
'Parts'
2 x surface mount (0805 size on the MK1 and MK2, 1206 size on the MK2a for easier soldering) or conventional through-hole LEDs. Install with opposite polarity so one or the other will light up regardless of the polarity of the power supply to the board.
1 x 1K ohm surface mount or through-hole resistor
MK2b Dual Power Technical Details
You can find the open source files here: http://forum.reprapdiscount.com/forums/oss/
  • Dimensions 214mmx 214mm
  • Laminate FR4 1.6+-0.15mm
  • 2 layer, 35μm copper
  • Red Soldermask - both sides
  • White Silkscreen - both sides
  • Power Input: 12V or 24v
  • copper plated holes
  • resistance between 1.0-1.2 ohm (12V) or 3-3.4 ohm (24V) (Sainsmart board came in at 1.8 ohm @ 12V/3.6 ohm @ 24V)
Very good in combination with RUMBA or Taurino Power
MK2 A4
This is my build. I always wanted a big bed, in order to be able to plot (yes, actually plot, with artistic purpouses) at least DIN A4 in size. So I built my prusa mendel big enough to be able to host such a HBP PCB. I'm no good with any PCB editor, so I made my files in a CAD program, and exported the result file into a dxf file. The file has several layers the names of which should make the information self understandable. Anyway I'll tell: the layers with number names represent the routing of the traces the width of which is the layer's name in mm. The design was basically copied from MK2a. The engineering was made with an evolutive algorithm developed by Damrod in grasshopper. The manufacturing was a bit faulty, but it works flawlessly.
  • Dimensions 215mmx 315mm
  • 1 layer 35μm copper
  • resistance between 1.0 and 1.2 ohm
source dxf
200X300 Heatbed MK3
The 200X300 Heatbed MK3 has a 100mm bigger built area then the regular MK2 heatbed and the overall outline is 214X314mm.
It has dual power mode optimized for 12 or 24V but you can also use everything in between (16V, 19V what have you) (Your printer controller will regulate the power to the heatbed in order to get your preset temperature.)
The core is regular 1.6mm FR4 PCB and the print surface is the same as regular heatbeds but with a metric ruler grid.
The connections to the heatbed is the same as the connections on the MK3 Alu. heatbed belov.
The 200X300 Heatbed MK3 is now available in the RepRap.me webshop.
  • Dimensions 214mm x 314mm
  • 1 layer 35μm (1oz base) copper
  • Resistance between 1 and 1.3 ohm for the 12V
  • Resistance between 4.5 and 5 ohm for the 24V
  • 110 degrees Celsius possible for both 12V and 24V
  • Running 24V on the 12V terminals will heatup the heatbed to 100 degree in only 2 minutes
  • 180 degree Celsius max. temperature
MK3 ALU-Heatbed Dual Power
The Alu-Heatbed MK3 have features similar to MK2 and you can also operate this board with 12V or 24V.
- Heatbed with 3.2mm Aluminum Core. Print directly on the heatbed, no need for glass plate. It's a much lighter solution than PCB heatbed + glass, which makes it better for faster prints.
- Dual power supply. Operate at 12V or 24V. You can use thinner wires when operating at 24V.
- A central mounting hole on the front side to allow for three point mounting. This is much easier for bed leveling in comparison to 4 point mounting. First level the side with two holes and fix in place, then level the side with one hole.
- Large solder pads for multiple wires (ribbon cable) or a SMD pinhead connector can be mounted.
- Pads for SMD thermistor 1206
  • Dimensions 214mm x 214mm
  • Resistance between 1.4 and 1.6 ohm for the 12V
  • Resistance between 5.0 and 5.4 ohm for the 24V
  • 100 degree Celsius possible for both 12V and 24V
  • With 15V on the 12V terminals will maintain approx. 115 degree Celsius without regulation
  • Running 24V on the 12V terminals will heatup the heatbed to 100 degree in only 2 minutes (Your printer controller will regulate the power to the heatbed in order to get your preset temperature.)
Alu heatbed.JPG Bottom side (Do not print directly on this side)
Alu TOP .jpg Top side (Printing side)
Recommended NTC: EPCOS - B57621C104J62 - THERMISTOR, 100K "or whatever you normally use."
Where to get it
www.RepRap.me
MK2a layout in SVG-format
There's an SVG-version (Inkscape) of the MK2a-layout.
For the toner transfer method and people that only have a printer for letter/DIN A4 there's a version with two separated parts. Because the parts only have few electrical contacts between them, they easily can be ironed next to each other, fixing the needed bridges with etch resistant paint before etching.
(You may follow the complete process here: Etched_heatbed_construction)
