Open Hybrid Mendel/Parts
Revision as of 18:50, 10 April 2014 by Tonyarm (talk | contribs) (Parts)
Parts
Download .rar: File:OpenHybridMendel 0.98.rar
Frame and Z Axis Parts
Quantity File-Name Comments Diagram
6 Camiel_frame_vertex_6off Alternative part by Camiel Camiel frame vertex 7off.JPG
4 pla_coupling_nophead-1piece_4off Alternative part by Nophead Pla coupling nophead.JPG
1 y-motor-bracket_1off_mod3-15 Modified by PSU Reprap Collective to remove vestigial endstop mount Y-motor-bracket 1off mod3-15.JPG
X Axis Parts
2 x-180-z-bearing-plate_2off From Sells Mendel X-180-z-bearing-plate 2off.JPG
2 PSU_x_vert_sideplate_360_end_2off Alternative part to x-ver-drive-side-plate-360-end_2off. This piece was made to separate the threaded and smooth z-rods on both sides of the x-axis. PSU x vert sideplate 360 end 2off1.JPG
2 x-360-z-bearing-plate_2off From Sells Mendel X-360-z-bearing-plate 2off.JPG
2 x-360-z-bearing-plate-mirror_2off From Sells Mendel X-360-z-bearing-plate-mirror 2off.JPG
1 xaxis-motor-bracket_1off Alternative part by Rhys-jones Xaxis-motor-bracket 1off.JPG
4 x-vert-drive-nut-trap_4off From Sells Mendel X-vert-drive-nut-trap 4off.JPG
4 x-vert-drive-side-plate_4off From Sells Mendel X-vert-drive-side-plate-180-end 2off.JPG
2 x-axis-side-plate-nut-jig_2off From Sells Mendel X-axis-side-plate-nut-jig 2off.JPG
1 pulley_w-set_screw_2off Same as in Frame and Z Axis Pulley w-set screw 2off.jpg
Y Carriage Parts
File:OHM OpenY.zip
1 OpenY_8mm Belt Harness_1off Open Y by Buback, modified by PSU Reprap Collective OpenY 8mm Belt Harness 1off.jpg
2 OpenY_8mm Crossbar Mount_2off Open Y by Buback 8mm Crossbar Mount 2off.JPG
1 OpenY_arm45 Open Y by Buback, modified by PSU Reprap Collective Arm 210.JPG
2 OpenXY_bracket Created by PSU RepRap Collective. Print two of these OpenXY bracket.jpg
X Carriage
File:OHM OpenX.zip
Two major issues affected the Open-X carriage: carriages occasionally "walk" up off the tracks, and inconsistent spacing of the undercarriage bracket occasionally allowed the extruder to move/twist laterally. Both of these issues were minimized through modifications by user Joe Bartolai. The OpenX Arm was shortened and an offset was added so that the bearing attached to it is centered on the rail. The OpenX undercarriage bracket was also modified by making the angle steeper where the lower bearings contact the rail and by increasing the spacing where the undercarriage bracket attaches to the carriage.
1 OpenX_arm_PSU_1off Open X by Buback Modified by PSU Reprap Collective OpenX arm PSU 1off.jpg
Extruder
File:OHM Extruder.zip
1 HerringboneDrivenGear
Herringbone Extruder Driver
Derived from anAlternative part by Rhys-jones. Current design by J.Bartolai HerringboneDrivenGear.JPG
1 HerringboneDriveGear Alternative part by Rhys-jones HerringboneDriveGear.JPG
1 Gregs_accessible_wades_v6
Greg's Hinged Extruder
Electronics Mounting
File:Electronics Mounting.zip
3 endstop-holder_large_endstop_3off Optical endstop holder (Not used by group, only using mechanical endstops) Endstop-holder large endstop 3off.jpg
3 endstop-holder_microsw-1_small enstops_3off Mechanical endstop holder Endstop-holder microsw-1 small enstops 3off.jpg
Printer Accessories
File:Printer Accessories.zip
1 tweezer_and_allen_key_holder Created by Crosby and Dimitri Endstop-holder large endstop 3off.jpg
Spindle Pieces
File:Spindle Pieces.zip
2 axis_holder created by Armlin Axis holder.jpg_
Preliminary Redesigned Parts
Quantity of Materials Needed by Subsystem
Part Name Frame Z-Axis Open Y-Axis Open X-Axis X-Carriage Extruder Spindle Total
M3x6mm Flat Set Screw - - 1 1 - 1 - 3
M3x10mm Cap Screw - 8 - 4 - 4 - 16
M3x20mm Cap Screw - 9 1 9 - - - 19
M3x25mm Cap Screw - 4 - - - - - 4
M3 Washer - 26 6 22 - 4 - 58
M3 Nut - - 1 1 - 1 - 3
M3 Nylock - 9 1 9 - - - 19
M4x16mm Cap Screw - - - 4 - - - 4
M4x20mm Cap Screw - - 8 4 14 - - 26
M4x25mm Cap Screw - - 4 - - 3 - 7
M4x40mm Cap Screw - - 16 30 - 2 - 48
M4x50mm Cap Screw - - 4 - - - - 4
M4 Washer - - 72 84 34 8 - 198
M4 Large OD Washer (3/16 fender washer) - - 8 8 - - - 16
M4 Nut - - - 8 - 3 - 11
M4 Nylock - - 32 30 14 2 - 78
M8 Washer 72 12 4 - - 2 24 114
M8 Nut 72 8 4 2 - - 52 138
M8 Nylock - - - - - 1 - 1
Bearing 8x22x7 mm - - - - - 3 2 5
Bearing 4x13x5 mm - - 12 14 10 - - 36
Older complete version: File:OpenHybridMendel 0.96.rar
Threaded Rod and Smooth Rod
See the following page for a list of all the threaded and smooth rods required and how to cut them to length.
Full Rod Cut List
