Open Hybrid Mendel
Revision as of 16:20, 16 September 2011 by Joshj (talk | contribs) (Parts)
Open Hybrid Mendel (OHM)
Release status: Working
A hybrid between Prusa and Mendel models using several improved pieces from the community
GPL
Overview
The Open Hybrid Mendel (or OHM) is a project of the Penn State Reprap User Group. It is a Mendel design, which uses both standard Sells Mendel parts, a Prusa Z drive, various redesigns from the community at large, and a number of small design improvements developed in our PSU Reprap class, in the spirit of open source design (see the wiki page on closed innovation for a good comparison of methodologies ) It is so named due to this hybridization of designs, and obtains the 'Open' designation from the OpenX and OpenY axes it uses. The prototype for the OHM design was Etherdais_Unit_One
Expanding into the realm of the biological, the OHM is the basis for a Mendel-based PCR system, currently designated the RepRap Mullis.
Any Mendel can be broken down into 6 sub-systems, which are somewhat interchangable between designs:
Frame - The OHM uses Camiel's thin shelled Vertex design, maintaining vertices similar to the Sells design, but using less filament
Y-axis - The OHM uses a modified OpenY, with an optoless belt harness, and a second 90/180 arm in place of the 90/270 arm. This demands two additional bearings, but we find the result is more stable, while retaining the benefits of the OpenY. A modified Sells y-motor bracket is used, which avoids printing an unused endstop holder from the original Sells design. The original Sells y-bar clamps seem well suited for mounting y-axis opto-endstops.
Z-drive system - The OHM uses a Prusa, double motor design for driving the Z axis, avoiding the large prints and continuous belt of the Sells Z-drive design. We still use Sells bar clamps to clamp the smooth rod to the Z-motor mounts, as they are compatable, and look sharp together.
X-Z assembly - Currently, the OHM build uses a standard Sells X-Z assembly, as described here in Mendel_X-axis.
Carriage - The OpenX carriage is the design of choice currently. This, and the OpenY
Extruder - We are in the process of finding a design which is more compatable with the TechZone steel hot tips we've been using recently, though the current design is a hack of herringbone extruder gears, and GregFrost's hinged wades extruder.
Parts
Download Zip: File:OpenHybridMendel 0.1.zip
Quantity File-Name Comments Diagram
6 camiel_frame_vertex_6off Alternative part by Camiel Camiel frame vertex 7off.JPG
4 pla_coupling_nophead-1piece_4off.STL Alternative part by Nophead Pla coupling nophead.JPG
1 xaxis-motor-bracket_1off Alternative part by Rhys-jones Xaxis-motor-bracket 1off.JPG
2 x-vert-drive-side-plate-180-end_2off X-vert-drive-side-plate-180-end 2off.JPG
2 x-vert-drive-side-plate-360-end_2off_rebuild X-vert-drive-side-plate-360-end 2off rebuild.JPG
1 y-motor-bracket_1off_mod3-15 Modified by PSU Reprap Collective Y-motor-bracket 1off mod3-15.JPG
1 OpenX_Undercarriage_Bracket_1off Open X by Buback OpenX Undercarriage Bracket.JPG
1 8mm_Belt_Harness_1off Open Y by Buback, modified by PSU Reprap Collective 8mm Belt Harness 1off.JPG
1 OpenY_Undercarriage_Bracket_1off Open Y by Buback OpenY Undercarriage Bracket.JPG
3 electronics_board_mount_opt Created by RUG member SethG Electronics board mount.JPG
2-5 prusa_modified_endstop_holder_2-5off Prusa opto holder modified to have a thicker end No picture yet
Extruder
Currently not included in STL zipfile
1 HerringboneDrivenGear Alternative part by Rhys-jones HerringboneDrivenGear.JPG
1 HerringboneDriveGear Alternative part by Rhys-jones HerringboneDriveGear.JPG
1 Gregs_accessible_wades_v6 Alternative extruder by Greg-Frost Gregs accessible wades v6.JPG
