Ohm/How to build an OHM
Revision as of 12:45, 22 April 2013 by Mbilyk (talk | contribs) (Frame)
Introduction
The Open Hybrid Mendel (OHM) has several advantages over the generic Mendel model. Mainly, it is more flexible. The extruder carriage and printing board are designed to easily pop off the machine without unscrewing any parts.
All STL files mentioned in this article are referring to, and can be downloaded from the OHM Parts section.
Mechanical Construction
Frame
Frame Triangles
Parts
To make the frame triangles, 6 frame vertices, 2 bar clamps and 6 threaded bolts are needed.
Frame Vertex part
Bar Clamp part
Assembly
(Assembly guide. Delete this note when section is finished)
Tips
(Extra tips to help assemble. Delete this note when section is finished)
Connecting the Triangles
Parts
(Parts needed for assembly. Delete this note when section is finished)
Assembly
Tips
X-Z Assembly
Z-Axis Motor Mounts
Parts
Assembly
Tips
X-Axis Motor Mounts
Parts
Assembly
Tips
X-axis Z-bar clamp
Parts
Assembly
Tips
Putting it all together
Parts
Assembly
Tips
Z Drive System
OpenY Axis
Carriage
Extruder
This unfinished part includes the main driven gear, idler and lastly the main section.
Spool Arm
