Ohm/How to build an OHM
Revision as of 19:16, 1 November 2012 by Afs2015 (talk | contribs) (moved How to build an OHM to Ohm/How to build an OHM: More appropriate as a sub-page of Ohm instead of the root directory.)
The Open Hybrid Model (OHM) has several advantages over the generic Mendel model. Mainly, it is more flexible. The printing board is designed to easily pop off the machine without unscrewing any parts.
All STL files mentioned in this article are referring to and can be downloaded from OHM Parts section.
Mechanical Construction
Frame
To make the frame triangles, 6 frame vertices, 2 bar clamps and 6 threaded bolts are needed.
