Nichrome
Revision as of 20:54, 26 May 2013 by Virtlink (talk | contribs) (Linkfix)
Nichrome Wire also known as Nickel Chromium Wire is a type of resistive heating element used in just about any electric heating device such as an Extruder and Heated Bed. RepRap uses Nichrome 80 which is composed of 80% Nickel and 20% Chromium.
Insulated Nichrome wire is generally preferable to prevent a short circuit but uninsulated wire should work as long as extra measures are taken to insulate the wires from each other. Kapton Tape or alternatively Teflon Tape is utilized for extra insulation.
You can buy Nichrome wire online, and it's a good idea to use a RepRap supplier to ensure you get the correct type.
It's also possible to find Nichrome wire and insulation at local shops, typically the ones that sell parts for electric machines. (Here is a picture of the Casainho extruder using Nichrome wire and insulation, both bought on local shop).
Vitamin?
In RepRap-English, a Vitamin is anything that you need to make a RepRap, which a RepRap cannot itself make. Printed circuit boards, or stepper motors are vitamins right now. Plastic stuff is not. We're good at making that stuff.
Used By
Suppliers
External References
RepRap Forum:RepRappers-Nichrome Wire
Note: This is a link from the wiki to stuff that should be on the wiki.  We need a template for this, because that stuff is everywhere.
