NewHost Skeinforge
Revision as of 02:21, 12 August 2010 by Stoffel15 (talk | contribs) (Created page with 'This is a Special Skeinforge Build on version: 2010-04-27 00:14:23 CET beta This is the Last Version with a working Comb-Funktion. The Export.py is Patched to delete The M-Codes…')
The Export.py is Patched to delete The M-Codes.
def getNonskipped( gcodelines ):
"Skip lines containing undesired commands."
result = ""
for line in gcodelines.split('\n'):
if line.startswith("M101"): continue #lines to skip
if line.startswith("M103"): continue
if line.startswith("M105"): continue
if line.startswith("M108"): continue
result += line + '\n'
--Stoffel15 06:21, 12 August 2010 (UTC) return result
