Mondrian User Manual
Revision as of 04:41, 30 December 2014 by Glenn (talk | contribs) (catchg)
Mondrian Documentation
Firmware
XY
Twin motors Y
Using a board with two Z terminal for an easy wiring (like on the Azteeg_X1 or Minitronics_10)
Original Sanguinololu pins :
#define Y_STEP_PIN         22
#define Y_DIR_PIN          23
#define Y_STOP_PIN         19
#define Z_STEP_PIN         3
#define Z_DIR_PIN          2
#define Z_STOP_PIN         20
So we just need to invert them :
#define Y_STEP_PIN         3 // 22
#define Y_DIR_PIN          2 // 23
#define Y_STOP_PIN         20 // 19
#define Z_STEP_PIN         22 // 3
#define Z_DIR_PIN          23 // 2
#define Z_STOP_PIN         19 // 20
don't forget the enable pins too (I don't know why but I had to disable the Z_enable_pin)
#define X_ENABLE_PIN       14
#define Y_ENABLE_PIN       26 // 14
#define Z_ENABLE_PIN       -1 // 26
#define E0_ENABLE_PIN       14
H-bot
  • Motor on the right, connected to the X driver
  • Motor on the left, connected to the Y driver
  • False, false for both
