Mondrian Build Manual
- 1 Previous Versions
- 2 Tools
- 3 General tips
- 4 Step 1/18 - Corners (base)
- 5 Step 2/18 - Base frame
- 6 Step 3/18 - Endstops
- 7 Step 4/18 - Z-sliders
- 8 Step 5/18 - Z-pillars
- 9 Step 6/18 - Z-motor
- 10 Step 7/18 - Z-axis
- 11 Step 8/18 - Bed
- 12 Step 9/18 - Corners (top)
- 13 Step 10/18 - Y-sliders
- 14 Step 11/18 - X-slider
- 15 Step 12/18 - Hotend
- 16 Step 13/18 - Back panel
- 17 Step 14/18 - Wiring
- 18 Step 15/18 - Finishing touches
- 19 Step 16/18 - Driver
- 20 Step 17/18 - Firmware
- 21 Step 18/18 - Software
- 22 Step 19/20 - Bed calibration
- 23 1st printing
Previous Versions
Tools
General tips
<videoflash>oy6gteUXlsY</videoflash>
- Read the whole manual before starting to get an overview of the building steps (total: 12 hours of assembly).
- The FoldaRap is made of a base frame and several sub-assemblies. Some can be done in parallel to save time, gather your friends and establish a new building time record !
- Work on a cutting mat if you have one: it will protect your table plus they often show a millimetre grid that can be useful to check the bolts length (with experience you will recognize them by looking or holding one).
- Place your mouse over a picture to know the element name.
- Do not hesitate to have a look at the 3D model in SketchUp (before/during the build): it will show you the folded/unfolded state of the machine and you can play around with it.
Printed parts
Lasercut parts
Insert a T-nut
x4 corner-base x8 605zz bearing
x1 closed-loop-belt x4 threaded-rod x8 M5 washer
x4 M4x8 x4 T-nut x4 300mm profile x1 panel-bottom
X-endstop
Y-endstop
Z-endstop
x1 z-slider-endstop x1 endstop x2 ferrule
x3 z-slider x1 z-slider-endstop x8 nylon nut
x4 300mm profile x8 M4x8 x8 T-nut
Step 6/18 - Z-motor
Z-motor
x1 nema 17 x1 pulley x2 grub screw
x2 M3x20 x4 M3 washer x4 roulement 623zz x2 M3 washer (large)
Toothed-wheel
x1 belt adjuster x1 M3 nut x1 M3x25 x2 roulement 623zz x2 M3 washer x2 M3 washer (large)
Step 7/18 - Z-axis
x1 panel-z-axis x4 M3x16 x4 M3 nut
Step 8/18 - Bed
x2 2,54mm female ferrule x1 2-pin casing
x3 M3x35 countersunk x3 M3 nut x3 spring x3 wingnut
x3 corner-top x1 corner-top-camera x8 M4x8 x8 T-nut
x2 300mm profile x4 M4x8 x4 T-nut
x1 nema 14 x1 pulley x2 grub screw
x1 y-slider left x2 M3x30 countersunk
x1 360mm belt x2 M3x30 countersunk x2 603zz bearing
x2 x-belt end x2 M4x8 x2 T-nut
x1 y-slider right x1 nema 14 x1 pulley x6 grub screw x1 300mm profile x4 M3x30 countersunk x2 603zz bearing x1 360mm belt x2 x-belt end x2 M4x8 x2 T-nut
X-slider
x1 x-slider x1 300mm profile x4 grub screw
x1 360mm belt
x2 603zz bearing
Y-endstop
X-endstop
Blower
x1 blower x2 ferrule x2 heatshrink tubing x2 cable terminal
LEDs strip
Step 12/18 - Hotend
Hotend
x1 heater block x1 nozzle x1 barrel
x1 cartridge heater x1 grub screw
x1 heatsink x1 pneumatic fitting x1 PTFE tube x1 grub screw
x1 fan grill x1 fan x4 M3x16 x4 M3 washer
x1 6pin male casing x6 female ferrule
Cable harness
x1 6pin female casing x6 male ferrule
X-axis
Plugs & Switch
x1 4,8mm ferrule (+ insulation) x1 6,35mm ferrule (+ insulation)
x1 panel-back x1 plug x1 switch x2 M3x8 x2 M3 nut
Extruder
x1 extruder x1 M3x16 x1 603zz bearing
x2 M3x35 x2 spring x2 M3 washer x2 M3 nut
x2 door-lock-inner x2 door-lock-outer x2 M3x12 x2 M3 nut
Electronic panel
x1 electronic-cover-1 x1 fan x4 M3x16 x4 M3 nut
x1 power supply x4 M3x8 x4 M3 nut
Step 14/18 - Wiring
X-motor
Y-motors
Z-motor
E-motor
Electronic board
Cables-path
Electronic cover
Endstop
x1 endstop-stop x1 M4x8 x1 T-nut
Panel-sides
x2 panel-side x8 M4x8 x8 T-nut
PTFE tube
Spool holder
Noodles cup
Door
Step 16/18 - Driver
download the adapted driver on: http://www.ftdichip.com/Drivers/VCP.htm
download the Mondrian file on: https://github.com/EmmanuelG/Mondrian
download Arduino 1.6.3 on: http://reprapworld.com/?software
User interface
download printrun 03Feb2015 on: http://koti.kapsi.fi/~kliment/printrun/
here is a short tutorial on Pronterface: http://www.plasticscribbler.com/tutorial/getting-started/item/21-getting-started-with-pronterface#.VZZMAUaVM9p
Testing
X testing
If the motor rotation is reversed go the the "readjustments" paragraph...
Y testing
Z testing
Hotend testing and adjustment
Extruder testing
Bed testing
Readjustments
Endstops testing
1st printing
Modelling
Netfabb Basic
Check the quality of your .stl file on Netfabb Basic: you might "repair" or re-arrange your .stl file on Netfabb
download and install Netfabb Basic on: http://www.netfabb.com/downloadcenter.php?basic=1
if you want to know more about the Netfabb Basic functions download the tutorials on: http://www.netfabb.com/tutorials.php
If the automatic repair doesn't wotk: use the red cross button to identify the origin of the problem and re-open your file under the CAD software extension to correct the problem manually (don't forget to re-export the model as a .stl file)
Slic3r
Define the printing parameters of your model in Slic3r
download Slic3r on: http://slic3r.org/download
have a look on the Slic3r manual if you want to know more about Slic3r: http://manual.slic3r.org/
Pronterface
Drive your 3D-printer with Pronterface
Your Mondrian is now ready. Have a lot of fun with your projects!
