Mondrian Build Manual
Revision as of 07:26, 6 February 2015 by Emmanuel (talk | contribs) (Z-drive)
Mondrian Documentation
Assembling and setting up the machine should take between 4h to 8h or two afternoons :) If you preassemble everything, or if you disassemble your machine for a travel, it should take 1h to put it back together.
<videoflash>QuMhb-vMsfw</videoflash>
General tips
Read the whole manual once or twice before starting, to get an overview of the build
Know the parts
Firstly, have a look at all the part and learn what everything is.
How to insert a T-nut
T-nut insertion.jpg Tightening torque : 2.5 Nm (+/- 5%)
<videoflash>9CAiVmfO2mk|320|240</videoflash>
Base frame
Mondrian2 base-corner.png x4 base-corner
20x20 300mm.jpg x4 300mm profile M4x8 round-head.jpg x4 m4x8 T-nut.jpg x4 m4 t-nut
Base-frame 2.png x4 base corner assembly Mondrian2 bottom-plate.png x1 bottom-plate
Z-sliders
Mondrian2 z-slider.png x3 z-slider Mondrian2 z-slider endstop.png x1 z-slider for endstop
20x20 300mm.jpg x4 300mm profile M4x8 round-head.jpg x8 m4x8 T-nut.jpg x8 m4 t-nut
Mondrian2 corner-top.png x3 top corner Mondrian2 corner-top camera.png x1 top corner for z-endstop
20x20 300mm.jpg x2 300mm profile M4x8 round-head.jpg x2 m4x8 T-nut.jpg x2 m4 t-nut
Y-sliders
Mondrian2 y-slider L.png Y-slider left Mondrian2 y-slider R.png Y-slider right
Nema14.jpg x2 nema14 stepper motor Timing pulley2.png x2 pulley
M3x30 countersunk-head.jpg x8 m3x30 counter-sunk 603zz.png x4 603zz bearing
The instruction show the left side, it will be the same (in mirror) for the right side.
20x20 300mm.jpg x2 300mm profile T2.5belt.jpg x2 360mm belt M4x8 round-head.jpg x4 m4x8 T-nut.jpg x4 t-nut
Z-drive
1350mm closed-belt.jpg x1 closed-belt 230-235mm threaded-rod.jpg x4 m5 threaded rod 300mm M5 nut.jpg x8 m5 nut Mr105zz.png x4 mr105zz bearing Timing pulley.jpg x4 pulley M5-nylon-nut.png x8 m5 nylon nut
Nema17.png x1 nema 17 623zz.jpg x6 623zz bearing M3x10 2.png x2 m3x10
M3x20.jpg x2 m3x20 M3x25TCHC.jpg x1 m3x25 M3 washer.jpg x8 washer
M3 large washer.png x4 large washer M3 nut.jpg x1 m3 nut Mondrian2 m3-nut-housing.png x1 m3 nut housing
Bed
T-nut.jpg x1 m4 t-nut M4x10.png x1 m4x10
Mondrian2 Z-plate.png x1 Z-plate M3x16.jpg x4 m3x16 M3 nut.jpg x4 m3 nut
Microswitch 2.PNG x1 microswitch Ferule.JPG x2 ferule Heatshrink-tubing.JPG heatshrink tubing 2pin-wire connector.JPG x1 2pin wire with connector
Foldarap1.1 bed-plate.jpg x1 bed plate Foldarap2 kapton-heater.jpg x1 film heater Mondrian2 m3-nut-housing.png x3 m3 nut housing
M3x30 countersunk-head.jpg x3 m3x35 countersunk head M3 nut.jpg x6 m3 nut Bed springs RS751455.jpg x3 spring
  1. zip-tie wires
  2. cup-noodle
Rear Panel
Flat-120w-psu.jpg x1 power supply 150W Back panel.png x1 back panel C14 CEI male-plug.jpg x1 plug Switch.jpg x1 switch Minitronics v1-1.png x1 minitronics 1.1 M4x8 round-head.jpg x8 M4x8 T-nut.jpg x8 M4 T-nut Extruder nema17 2.png x1 extruder 17
  1. prep switch+plug
  2. add psu
  3. wires AC in, DC out
  4. extruder
  5. board
    1. E wire, Z wire, DC in
  1. add back panel
    1. z-endstop, bed ntc, bed heat
X-axis
  • x-slider
Nema14.jpg x1 nema14 stepper motor Timing pulley2.png x1 pulley
M3x30 countersunk-head.jpg x4 m3x30 counter-sunk 603zz.png x2 603zz bearing
  • y-endstop
  • x-endstop
  • blower
  1. check movement
  2. prep Y-endstop
  3. prep X-endstop
  4. motor+pulley+bearings
  5. belt
  6. blower
Hotend
  1. hotend with hotend-holder
  2. tubing
  3. if good, wire NTC+Heat+Fan
  4. if self build, heat to tighten
  5. put in x-slider
  6. check movement, file if necessary
Wiring
  1. bed ok
  2. back panel ok
  3. x-axis ok
  1. hotend
  2. y-motors+led
Calibration
  • config file to use (board)
  • making the bed parallel
  • config file to use (software)
  1. then
    1. elec cover + fan (File:Fan404010.png + m3x16 + m3nut)
    2. side panels
    3. door
  2. celebrate
