Mondrian Build Manual
Revision as of 12:11, 10 November 2014 by Emmanuel (talk | contribs) (Z-drive)
Mondrian Documentation
Assembling and setting up the machine should take between 4h to 8h or two afternoons :) If you preassemble everything, or if you disassemble your machine for a travel, it should take 1h to put it back together.
<videoflash>QuMhb-vMsfw</videoflash>
General tips
Read the whole manual once or twice before starting, to get an overview of the build
Know the parts
Firstly, have a look at all the part and learn what everything is.
How to insert a T-nut
T-nut insertion.jpg Tightening torque : 2.5 Nm (+/- 5%)
<videoflash>9CAiVmfO2mk|320|240</videoflash>
Base frame
Mondrian2 base-corner.png x4 base-corner
20x20 300mm.jpg x4 300mm profile M4x8 round-head.jpg x4 m4x8 T-nut.jpg x4 m4 t-nut
Base-frame 2.png x4 base corner assembly Mondrian2 bottom-plate.png x1 bottom-plate
Z-sliders
Mondrian2 z-slider.png x3 z-slider Mondrian2 z-slider endstop.png x1 z-slider for endstop
20x20 300mm.jpg x4 300mm profile M4x8 round-head.jpg x8 m4x8 T-nut.jpg x8 m4 t-nut
Mondrian2 corner-top.png x3 top corner Mondrian2 corner-top camera.png x1 top corner for z-endstop
20x20 300mm.jpg x2 300mm profile M4x8 round-head.jpg x2 m4x8 T-nut.jpg x2 m4 t-nut
Y-sliders
Mondrian2 y-slider L.png Y-slider left Mondrian2 y-slider R.png Y-slider right
Nema14.jpg x2 nema14 stepper motor Timing pulley2.png x2 pulley
M3x30 countersunk-head.jpg x8 m3x30 counter-sunk 603zz.png x4 603zz bearing
The instruction show the left side, it will be the same (in mirror) for the right side.
20x20 300mm.jpg x2 300mm profile T2.5belt.jpg x2 360mm belt M4x8 round-head.jpg x4 m4x8 T-nut.jpg x4 t-nut
Z-drive
1350mm closed-belt.jpg x1 closed-belt 230-235mm threaded-rod.jpg x4 m5 threaded rod 300mm M5 nut.jpg x8 m5 nut Mr105zz.png x4 mr105zz bearing Timing pulley.jpg x4 pulley M5-nylon-nut.png x8 m5 nylon nut
623zz.jpg x6 623zz bearing
Bed
Panels
X-axis
Wiring
Calibration
