Mondrian2.2 Build Manual
Revision as of 04:25, 16 March 2016 by N Sk (talk | contribs) (Created page with "Category:Mondrian Category:Build manuals The build manual for the Mondrian most recent version is here. Category:Mondrian File:Mondr...")
Mondrian 2.2
Previous versions
The build manual for the previous versions are here :
The build instructions for the Mondrian 3.0 are under redaction.
Tools
General tips
<videoflash>oy6gteUXlsY</videoflash>
  • Read the whole manual before starting to get an overview of the building steps (total: 12 hours of assembly).
  • The FoldaRap is made of a base frame and several sub-assemblies. Some can be done in parallel to save time, gather your friends and establish a new building time record !
  • Work on a cutting mat if you have one: it will protect your table plus they often show a millimetre grid that can be useful to check the bolts length (with experience you will recognize them by looking or holding one).
  • Place your mouse over a picture to know the element name.
  • Do not hesitate to have a look at the 3D model in SketchUp (before/during the build): it will show you the folded/unfolded state of the machine and you can play around with it.
Printed parts
Lasercut parts
Electric parts
Insert a T-nut
Step 1/18 - Corners (base)
M22-base-corner.png x4 corner-base Mr105zz.png x8 605zz bearing
Timing pulley2.png x4 pulley FRM-screw threads x3.png x8 grub screw
Belt-closed.png x1 closed-loop-belt 230-235mm threaded-rod.jpg x4 threaded-rod M3 washer.jpg x8 M5 washer
Step 2/18 - Base frame
M4x8 round-head.jpg x4 M4x8 T-nut.jpg x4 T-nut 20x20 300mm.jpg x4 300mm profile M22-panel-bottom.png x1 panel-bottom
Step 3/18 - Endstops
FRM-heatshrink-tubing.png x1 heatchrink tubing
X-endstop
Micro-switch with-lever.jpg x1 endstop FRM-ferule.png x2 ferrule
Y-endstop
Z-endstop
M22-z-slider-endstop-holder.png x1 z-slider-endstop Micro-switch with-lever.jpg x1 endstop FRM-ferule.png x2 ferrule
Step 4/18 - Z-sliders
M22-z-slider.png x3 z-slider M22-z-slider-endstop-holder.png x1 z-slider-endstop M5-nylon-nut.png x8 nylon nut
Step 5/18 - Z-pillars
20x20 300mm.jpg x4 300mm profile M4x8 round-head.jpg x8 M4x8 T-nut.jpg x8 T-nut
Step 6/18 - Z-motor
Z-motor
Nema14.jpg x1 nema 17 Timing pulley2.png x1 pulley FRM-screw threads x3.png x2 grub screw
M3x10 2.png x2 M3x10 M3 washer.jpg x2 M3 washer
M3x25TCHC.jpg x2 M3x20 M3 washer.jpg x4 M3 washer 603zz.png x4 roulement 623zz M3 large washer.png x2 M3 washer (large)
Toothed-wheel
Adjuster-lock-outer-01.png x1 belt adjuster M3 nut.jpg x1 M3 nut M3x25TCHC.jpg x1 M3x25 603zz.png x2 roulement 623zz M3 washer.jpg x2 M3 washer M3 large washer.png x2 M3 washer (large)
Step 7/18 - Z-axis
M22-panel-z-axis.png x1 panel-z-axis M3x16.jpg x4 M3x16 M3 nut.jpg x4 M3 nut
Step 8/18 - Bed
FRM-end-piece.png x2 cable terminal (1.5mm)
Mini-fit fiche-femelle.jpg x2 2,54mm female ferrule 2-pin.png x1 2-pin casing
M3x30 countersunk-head.jpg x3 M3x35 countersunk M3 nut.jpg x3 M3 nut Bed springs RS751455.jpg x3 spring Wingnut-hi-01.png x3 wingnut
Zipties.jpg x2 zip-tie
Step 9/18 - Corners (top)
M22-top-corner.png x4 corner-top M4x8 round-head.jpg x8 M4x8 T-nut.jpg x8 T-nut
20x20 300mm.jpg x2 300mm profile M4x8 round-head.jpg x4 M4x8 T-nut.jpg x4 T-nut
Step 10/18 - Y-sliders
Nema14.jpg x1 nema 14 Timing pulley2.png x1 pulley FRM-screw threads x3.png x2 grub screw
M22-y-slider-left.png x1 y-slider left M3x30 countersunk-head.jpg x2 M3x30 countersunk
FRM-belt.png x1 360mm belt M3x30 countersunk-head.jpg x2 M3x30 countersunk 603zz.png x2 603zz bearing
20x20 300mm.jpg x1 300mm profile
FR2-5-x-belt-end.png x2 x-belt end M4x8 round-head.jpg x2 M4x8 T-nut.jpg x2 T-nut
FRM-screw threads x3.png x4 grub screw
M22-y-slider-right.png x1 y-slider right Nema14.jpg x1 nema 14 Timing pulley2.png x1 pulley FRM-screw threads x3.png x6 grub screw 20x20 300mm.jpg x1 300mm profile M3x30 countersunk-head.jpg x4 M3x30 countersunk 603zz.png x2 603zz bearing FRM-belt.png x1 360mm belt FR2-5-x-belt-end.png x2 x-belt end M4x8 round-head.jpg x2 M4x8 T-nut.jpg x2 T-nut
Step 11/18 - X-slider
X-slider
Mondrian2 x-slider.png x1 x-slider 20x20 300mm.jpg x1 300mm profile FRM-screw threads x3.png x4 grub screw
Y-endstop
X-endstop
Blower
Fan404010.png x1 blower FRM-ferule.png x2 ferrule FRM-heatshrink-tubing.png x2 heatshrink tubing FRM-end-piece.png x2 cable terminal (1mm)
LEDs strip
Step 12/18 - Hotend
Hotend
FRM-heater-block.png x1 heater block FRM-nozzle.png x1 nozzle FRM-barrel.png x1 barrel
FRM-thermistor.png x1 thermistor FRM-screw threads x3.png x1 grub screw
FRM-cartridge-heater.png x1 cartridge heater FRM-screw threads x3.png x1 grub screw
FRM-hotend-heatsink.png x1 heatsink FRM-pneumatic-fitting-MA1203M5.png x1 pneumatic fitting FRM-PTFE-tube.png x1 PTFE tube FRM-screw threads x3.png x1 grub screw
FR2-5-hotend-holder.png x1 hotend holder M3x8.jpg x4 M3x8
FR2-5-fan-railings.png x1 fan grill Fan404010.png x1 fan M3x8.jpg x4 M3x16 M3 washer.jpg x4 M3 washer
Molex-6-pin-male.png x1 6-pin male casing Mini-fit fiche-femelle.jpg x6 female ferrule
M3x25TCHC.jpg x2 M3x25
Cable harness
Molex-6-pin-female.png x1 6-pin female casing Mini-fit fiche-male.jpg x6 male ferrule
X-axis
Step 13/18 - Back panel
Plugs & Switch
6,35mm-faston-ferule.jpg x1 4,8mm ferrule (+ insulation) 6,35mm-faston-ferule.jpg x1 6,35mm ferrule (+ insulation)
M22-panel-back.png x1 panel-back C14 CEI male-plug.jpg x1 plug Switch.jpg x1 switch M3x8.jpg x2 M3x8 M3 nut.jpg x2 M3 nut
USB-plug.png x1 USB port M3x8.jpg x2 M3x8
Extruder
Nema14.jpg x1 nema 17 FRM-insert.png x1 insert
M22-extruder.png x1 extruder M3x16.jpg x1 M3x16 603zz.png x1 603zz bearing
M3x25TCHC.jpg x3 M3x25
M3x35.jpg x2 M3x35 Bed springs RS751455.jpg x2 spring M3 washer.jpg x2 M3 washer M3 nut.jpg x2 M3 nut
Door-lock-inner.png x2 door-lock-inner Door-lock-outer.png x2 door-lock-outer M3x10 2.png x2 M3x12 M3 nut.jpg x2 M3 nut
M4x8 round-head.jpg x6 M4x8 T-nut.jpg x6 T-nut
Electronic panel
M22-panel-electronic-cover-1.png x1 electronic-cover-1 Fan404010.png x1 fan M3x16.jpg x4 M3x16 M3 nut.jpg x4 M3 nut
M3x8.jpg x4 M3x8 Strut.png x4 strut
M3x8.jpg x4 M3x8
FRM-power-supply-150w.png x1 power supply M3x8.jpg x4 M3x8 M3 nut.jpg x4 M3 nut
Step 14/18 - Wiring
X-motor
Y-motors
Z-motor
E-motor
Electronic board
Step 15/18 - Finishing touches
Cables-path
M4x8 round-head.jpg x1 M4x8 T-nut.jpg x1 T-nut
Electronic cover
M22-panel-electronic-cover-2.png x1 electronic-cover-2
Endstop
Endstop-stop.png x1 endstop-stop M4x8 round-head.jpg x1 M4x8 T-nut.jpg x1 T-nut
Panel-sides
M22-panel-side.png x2 panel-side M4x8 round-head.jpg x8 M4x8 T-nut.jpg x8 T-nut
PTFE tube
Spool holder
Spool-holder.png x1 spool-holder
Noodles cup
M22-noodle-cup.png x1 cup
Door
M22-panel-door.png x1 door M4x8 round-head.jpg x5 M4x8 T-nut.jpg x5 T-nut
Step 16/18 - Driver
Step 17/18 - Firmware
Step 18/18 - Software
User interface
Testing
X testing
If the motor rotation is reversed go the the "readjustments" paragraph...
Y testing
Z testing
Hotend testing and adjustment
Extruder testing
Bed testing
Readjustments
Endstops testing
Step 19/20 - Bed calibration
1st printing
Modelling
Netfabb Basic
Check the quality of your .stl file on Netfabb Basic: you might "repair" or re-arrange your .stl file on Netfabb
If the automatic repair doesn't wotk: use the red cross button to identify the origin of the problem and re-open your file under the CAD software extension to correct the problem manually (don't forget to re-export the model as a .stl file)
Slic3r
Define the printing parameters of your model in Slic3r
Pronterface
Drive your 3D-printer with Pronterface
Your Mondrian is now ready. Have a lot of fun with your projects!
