Previous versions
The build manual for the previous versions are here :
Tools
1,5 mm hexagonal wrench (for the pulleys grub screw)
2,0 mm hexagonal wrench (for M3 counterksunk bolts and pneumatic fittings "MA-12-03-M5")
2,5 mm hexagonal wrench (for normal M3 cap-head bolts and the rounded M4 bolts used for the frame)
1 cross-head screwdriver (for the PSU screw terminals)
2,0 flat screwdriver (to set the drivers current)
1 flat-nose pliers or 5,5 mm flat spanner (for M3 nuts)
1 cutting pliers and / or automatic striper (to cut the wires and strip them)
1 lighter (to for the heat-shrink sleeves
1 file (to adjust the printed parts)
1 soldering iron (for the LEDs strip)
General tips
<videoflash>oy6gteUXlsY</videoflash>
- Read the whole manual before starting to get an overview of the building steps (total: 12 hours of assembly).
- The FoldaRap is made of a base frame and several sub-assemblies. Some can be done in parallel to save time, gather your friends and establish a new building time record !
- Work on a cutting mat if you have one: it will protect your table plus they often show a millimetre grid that can be useful to check the bolts length (with experience you will recognize them by looking or holding one).
- Place your mouse over a picture to know the element name.
- Do not hesitate to have a look at the 3D model in SketchUp (before/during the build): it will show you the folded/unfolded state of the machine and you can play around with it.
Printed parts
Lasercut parts
Insert a T-nut
tightening torque: 2.5 N.m (+/- 5%): use the small side of the 2.5 hexagonal wrench to get the ideal torque
Step 1/18 - Corners (base)
x4 corner-base
x8 605zz bearing
x4 pulley
x8 grub screw
x1 closed-loop-belt
x4 threaded-rod
x8 M5 washer
Step 2/18 - Base frame
x4 M4x8
x4 T-nut
x4 300mm profile
x1 panel-bottom
x4 M4x8
x4 T-nut
check the perpendicularity of the structure with the pattern and readjust it if necessary
Step 3/18 - Endstops
x1 heatchrink tubing
X-endstop
x1 endstop
x2 ferrule
take red/black wires + 2-pin connector
Y-endstop
x1 endstop
x2 ferrule
Z-endstop
x1 z-slider-endstop
x1 endstop
x2 ferrule
cut 30cm of red/black wires + 2-pin connector
Step 4/18 - Z-sliders
x3 z-slider
x1 z-slider-endstop
x8 nylon nut
screw the nylon nuts on the threaded rods
place the z-sliders on the nylon nuts: make sure that there is NO PLAY between the nylon nuts and the z-sliders (otherwise adjust the position of the nylon nuts on the threaded rods)
Step 5/18 - Z-pillars
x4 300mm profile
x8 M4x8
x8 T-nut
Step 6/18 - Z-motor
Z-motor
x1 nema 17
x1 pulley
x2 grub screw
lock the pulley with one grub screw on the flat part of the shaft
fix the motor on the lasercut part (be careful with the connector orientation)
x2 M3x10
x2 M3 washer
x2 M3x20
x4 M3 washer
x4 roulement 623zz
x2 M3 washer (large)
Toothed-wheel
x1 belt adjuster
x1 M3 nut
x1 M3x25
x2 roulement 623zz
x2 M3 washer
Step 7/18 - Z-axis
x1 panel-z-axis
x4 M3x16
x4 M3 nut
position the 4 z-sliders at the same height thanks to the pattern
Step 8/18 - Bed
x2 cable terminal (1.5mm)
one side of the aluminium bed has countersunk holes...
... the other one not... position the bed so that the countersunk holes are against the table
remove the plastic from the film heater and stick the film heater on the aluminium bed like shown on the picture
x2 2,54mm female ferrule
x1 2-pin casing
push the ferrules completely in the 2-pin casing
x3 M3x35 countersunk
x3 M3 nut
x3 spring
x3 wingnut
x2 zip-tie
fix the cables on the z-axis panel with zip-ties
Step 9/18 - Corners (top)
x4 corner-top
x8 M4x8
x8 T-nut
x2 300mm profile
x4 M4x8
x4 T-nut
Step 10/18 - Y-sliders
x1 nema 14
x1 pulley
x2 grub screw
x1 y-slider left
x2 M3x30 countersunk
check the alignement of the pulley teeth with the y-slider
x1 360mm belt
x2 603zz bearing
pass the belt over the pulley...
... and catch it with a M3x30 countersunk...
... and a 603zz bearing...
... on both sides of the y-slider
x1 300mm profile
make sure that the y-slider slides easily without play on the aluminium profile (if not: file a bit the inside part of the printed piece until it slides well)
x2 x-belt end
x2 M4x8
x2 T-nut
x4 grub screw
if necessary: reduce the play between the printed part and the aluminium profile with the 4 grubscrews
x1 y-slider right
x1 nema 14
x1 pulley
x6 grub screw
x1 300mm profile
x4 M3x30 countersunk
x2 603zz bearing
x1 360mm belt
x2 x-belt end
x2 M4x8
x2 T-nut
repeat the previous operations with the second y-axis
x4 M4x8
x4 T-nut
Step 11/18 - X-slider
X-slider
x1 x-slider
x1 300mm profile
x4 grub screw
make sure that the x-slider slides easily with no play on the aluminium profile (if not: file a bit the inside part of the printed piece until it slides well)
x1 nema 14
x1 pulley
x2 grub screw
check the alignement of the pulley teeth with the x-slider
x1 360mm belt
x2 603zz bearing
x2 300mm profile
x2 x-belt end
x2 M4x8
x2 T-nut
Y-endstop
X-endstop
Blower
x1 blower
x2 ferrule
x2 heatshrink tubing
x2 cable terminal (1mm)
LEDs strip
cut 60cm of red/black wires + 2-pin connector
Step 12/18 - Hotend
Hotend
x1 heater block
x1 nozzle
x1 barrel
screw the nozzle in the heater block (be careful with the nozzle orientation) until the flat part of the nozzle is aligned with the bottom part of the heater block
screw the barrel in the heater bloc until it touches the nozzle
x1 thermistor
x1 grub screw
position the thermistor in the heater block (be careful with the wires orientation)...
... and lock it with a grub screw
x1 cartridge heater
x1 grub screw
position the cartridge heater in the heater block (be careful with the wires orientation)...
x1 heatsink
x1 pneumatic fitting
x1 PTFE tube
x1 grub screw
screw the pneumatic fitting in the heatsink
pass the PTFE tube through the pneumatic fitting and the heatsink
push the PTFE tube completely in the barrel
push the barrel through the heatsink WHILE pushing the ring of the pneumatic fitting (make sure that the PTFE tube doesn't move up in the barrel)
lock the barrel in the heatsink with a grub screw once the barrel shoulder is aligned with the bottom part of the heatsink (~5mm)
x1 hotend holder
x4 M3x8
turn the heatsink on the other side: position the hotend holder over the heatsink and screw it with M4x8
file both sides of the support...
... unitl it fits perfectly with the x-slider and it is still easy to slide the whole head from one side of the profile to the other
if the bottom heater block is not well aligned with the upper part of the spout holes...
... unlock the grub screw and adjust the height (make sure that the PTFE tube doesn't move up in the barrel)...
... and lock it in the correct position
x1 fan grill
x1 fan
x4 M3x16
x4 M3 washer
x1 6-pin male casing
x6 female ferrule
crimp one female ferrule on each extremity...
... just like on the drawing
x2 M3x25
Cable harness
x1 6-pin female casing
x6 male ferrule
plug both connector and make sure that the cables alignment is correct and that the ferrules don't go out from their casing
X-axis
x4 M4x8
x4 T-nut
Step 13/18 - Back panel
Plugs & Switch
x1 4,8mm ferrule (+ insulation)
x1 6,35mm ferrule (+ insulation)
x1 panel-back
x1 plug
x1 switch
x2 M3x8
x2 M3 nut
x1 USB port
x2 M3x8
Extruder
x1 nema 17
x1 insert
x1 extruder
x1 M3x16
x1 603zz bearing
x3 M3x25
x2 M3x35
x2 spring
x2 M3 washer
x2 M3 nut
x2 door-lock-inner
x2 door-lock-outer
x2 M3x12
x2 M3 nut
x6 M4x8
x6 T-nut
Electronic panel
x1 electronic-cover-1
x1 fan
x4 M3x16
x4 M3 nut
x4 M3x8
x4 strut
turn the potentiometers COUNTERCLOCKWISE and SLOWLY to position them like on the drawing
x4 M3x8
x1 power supply
x4 M3x8
x4 M3 nut
Step 14/18 - Wiring
X-motor
add long wires + connector to the x-motor
Y-motors
bring the wires from Y-motor 2 out of the connector related with the electronic board...
bring the wires back in the connector
Z-motor
add short wires + connector to the z-motor
E-motor
add short wires + connector to the extruder motor
Electronic board
connect the wires according to the drawing (be careful with the wires colour)
pass the cables over the aluminium profile...
... and group them with the breaded sheath
Step 15/18 - Finishing touches
Cables-path
x1 M4x8
x1 T-nut
Electronic cover
x1 electronic-cover-2
Endstop
x1 endstop-stop
x1 M4x8
x1 T-nut
Panel-sides
x2 panel-side
x8 M4x8
x8 T-nut
PTFE tube
Spool holder
x1 spool-holder
Noodles cup
x1 cup
Door
x1 door
x5 M4x8
x5 T-nut
Step 16/18 - Driver
connect the 3D-printer to your computer
note the USB port COM number
Step 17/18 - Firmware
open the .ino file: Mondrian > Firmware > Marlin_M222_Minitronics > Marlin_M222_Minitronics.ino
select the electronic board type > Ministronics
select the port COM number
transfer the firmware on the electronic board
Step 18/18 - Software
User interface
extract the files and open Pronterface
enter the bed size: 200x200x200
tick the box "display temperature gauges"
Testing
X testing
test the x-motor movement: (+)10X moves the hotend of 10mm to the left (the hotend moves away from the x-endstop)
(-)10X moves the hotend of 10mm to the right (the hotend moves closer to the x-endstop)
If the motor rotation is reversed go the the "readjustments" paragraph...
Y testing
test the y-motor movement: (+)10Y moves the hotend of 10mm to the front (the bed moves away from the y-endstop)
(-)10Y moves the hotend of 10mm to the back (the bed moves closer to the y-endstop)
Z testing
test the z-motor movement: (+)1Z moves the bed of 1mm to the bottom (the bed moves away from the z-endstop)
(-)1Z moves the bed of 1mm to the top (the bed moves closer to the z-endstop)
Hotend testing and adjustment
set the hotend temperature to 230°C
remove the hotend from the x-axis (be careful: it's hot! use gloves): as the metal parts distort because of the heat it's necessary to screw tighter the nozzle in the heater block to make the junction with the barrel airtight
use 2 pair pliers to do that: 1 pair to hold the heater block and 1 pair to screw the nozzle
replace the hotend on the x-axis
Extruder testing
while the hotend is hot push the extrude botton with 10mm (if the hotend temperature is <150°C the printer will protect itself and won't extrude)
the e-motor turns clockwise
stop heating up the hotend
Bed testing
set the bed temperature to 60°C
Readjustments
if the motors rotation is reversed then disconnect the 3D-printer from Pronterface and re-open the firmware in Arduino 1.6.3 >> Configuration.h >> "Mechanical Settings" paragraph
define INVERT_?_DIR false // write "true" instead of "false" (or the contrary) for the axis which need to be reversed and transfer the new version of the firmware on your electronic board
test again the motors rotation
Endstops testing
Step 19/20 - Bed calibration
thanks to the Pronterface console move the bed down (+)3Z...
... and bring the nozzle over the first M3x30 countersunk (+)X and (+)Y
bring the nozzle to "0" (HOME Z)
IF the nozzle puts pressure on the bed...
... turn the bed adjuster counterclockwise...
... until the nozzle touches the bed without putting pressure on it
IF the nozzle doesn't touch the bed...
... turn the bed adjuster clockwise...
... and bring the nozzle over the second M3x30 countersunk (+)X and (+)Y
turn the bed adjuster until the nozzle touches the bed without putting pressure on it
... and bring the nozzle over the third M3x30 countersunk (+)X and (+)Y
1st printing
Modelling
draw a 40x40x5mm parallelepipoid on any computer aided design (CAD) software: Blender, 3D Slash, SketchUp, etc.
export the parallelepipoid as an .stl file (and under the CAD software extension)
Netfabb Basic
Check the quality of your .stl file on Netfabb Basic: you might "repair" or re-arrange your .stl file on Netfabb
open your .stl file in Netfabb Basic: if the file is ok every face appears in green and the software gives you the volume value in the right panel (you can also check the dimensions of your model)
if the .stl file is wrong: a warning sign appears and the software doesn't give you the volume value
to repair the .stl file: click on the red cross button (REPAIR)
select the automatic repair
apply repair and remove old part
don't forget to save the new version of yoour file: Part > Export part > as STL
If the automatic repair doesn't wotk: use the red cross button to identify the origin of the problem and re-open your file under the CAD software extension to correct the problem manually (don't forget to re-export the model as a .stl file)
Slic3r
Define the printing parameters of your model in Slic3r
extract the files and execute slic3r.exe
the Slic3r window opens without any installation
change the user mode: File > Preferences > Mode > Expert (then stop and restart SLic3r to integrate the changes)
load the config adapted for the Mondrian (from the Mondrian-master file from GitHub): File > Load Config... > Mondrian-master > software > config.ini (choose "05nozzle" if the nozzle diameter is of 0.5mm)
check if the configuration is well downloaded
open the .stl file in Slic3r: Add... > File.stl
export the G-code containing every settings about: Print / Filament / Printer
Pronterface
Drive your 3D-printer with Pronterface
the window Pronterface is probably still open and your printer still connected... if no: start again Pronterface and connect the machine on the correct port COM number and baudrate
set the bed temperature to 60°C...
... and the hotend temperature to 205°C
position the spool on the spool holder
pass the filament through the extruder...
... between the pulley and the bearing...
... then push manually...
... until you see the melted plastic passing through the nozzle (use the brucelle pliers to remove the melted plastic)
load the G-code on Pronterface...
... and print: the hotend and the bed will search automaticcaly the "0" position before starting to print
check the printing quality: if the nozzle is too high over the bed the filament won't stick on the Kapton (the filament draws small "waves")
if the nozzle is too low the filament looks thick or even doesn't extrude
if you notice one situation or the other adjust the bed level with the bed adjusters until the filament looks like on the picture
when your test parallelepipoid is finished wait the bed temperature to reach 45°C before removing the object (otherwise you can distort it)
check the object dimensions precision with a calliper (+/- 0.05mm)...
... and the object angles precision with a ruler and a set square (if the precision is not satisfying you might have to adjust the geometry of your machine: parallelism and perpendicularity of the aluminium profiles)
Your Mondrian is now ready. Have a lot of fun with your projects!
