MondoFrame
Revision as of 04:16, 17 December 2011 by Glenn (talk | contribs) (catchg)
Photo of an assembled complete frame
Assembly Tip
In order to make the frame construction go faster, it is suggested that you wrap one end of the threaded rod with tape (so the threads do not get damaged), insert the tape covered rod into the chuck of a hand drill and lightly tighten the chuck. You can now rotate the rod, instead of the nuts that need to be threaded onto the rod, making the positioning of the nuts much quicker.
Top Unit
Photo of the parts used in the top unit
Photo of an assembled top unit
Front Unit
Photo of the parts used in the Front unit
Back Unit
Photo of the parts used in the back unit
Photo of an assembled back unit
Motor Side Unit
Photo of the parts used in the motor side unit
Photo of an assembled motor side unit
Idler Side Unit
Photo of the parts used in the idler side unit
Photo of an assembled idler side unit
Center Unit
Photo of the parts used in the center unit
Photo of an assembled center unit
Bottom Unit
Photo of the parts used in the bottom unit
Photo of an assembled bottom unit
Complete Frame
Photo of the parts used in the complete frame
