Mini-Mendel Z-axis
Revision as of 11:35, 21 August 2010 by Mccoyn (talk | contribs) (Added build instructions for the belt blocks.)
Belt Blocks
This image shows the parts that are required to assembly the belt blocks.
Install the idlers. The tensioner is adjustable. I put it near the other idlers so that it is easy to install the belt. Later it will be adjusted.
Install the z-axis bar clamps. The nuts for these should be pulled in and trapped in the pockets.
Leadscrews
