Microstepping with optical feedback
Release status: unknown
Description | Microstepping with optical feedback
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Overview
The idea is to make a module that is a functional substitute for a 400 step stepper motor and a "dumb" stepper driver board. Stepper motors with fewer than 400 steps per rotation are easy to find as surplus equipment, either by themselves, or in old computer printers. Optical encoder strips and quadrature optical encoders are easy to get from junk ink-jet printers. In order to allow retrofitting of existing systems, it is desirable to have a setup that can take the PULSE and DIRECTION command signals usually accepted by stepper motor driver boards. These items can be combined to make high precision motion control setup that is quite useful.
Interface to gcode interpreter
My intent was to make this setup act like a stepper motor driver board, which it does. Because the step signal (PULSE) is being sampled by firmware, I have a simple pulse stretcher circuit that makes the pulses a little longer. I am using reprap-gen3-firmware-2009-08-05 (slightly tweaked) on the Arduino that generates the step and direction pulses. It makes 5 microsecond step pulses. This is a bit fast for my approx 30 KHz interrupt to detect reliably.
Stepper motor
This is a NEMA 17 motor on one axis, and larger cylindrical stepper on the other axis.
Drive Circuit
<schematic> The drive circuit uses a L298. I was pleasantly suprised that I could run it at about 30 KHz, but it seems to be working fine. This is connected directly to the stepper motor in a bipolar configuration. There is no output filtering on this signal, but I have not had EMI problems.
Feedback Loop
This system is a little different from a servo loop with a DC motor. If you put a voltage across the terminals of a DC motor, it revs up to a certain speed and will continue to rotate at that speed while the voltage is present. If you put voltages on the terminals of a stepper motor, it moves to a certain position, and then holds that position. This actually makes things easier. The feedback algorithm has a feedforward term that directly increments (or decrements) the phase when a pulse is received. There is also an integral error term that adds an offset proportional to the difference between where it is and where it is supposed to be (this is added to the phase repeatedly, which is what makes it integrate).
+---------------------------------------------+ | | V +---------------------------+ |
+-----------+ | | +---------+ |Quadrature |->|XENC +-------+ SINE-->PWM|->| | |encoder | | | | Feed | ^ | | | +-----------+ | V | back | | | | Stepper |
| +->| algor |->PHASE | | Motor |
+-----------+ | ^ | ithm | | | | | |Stepper | | | +-------+ V | | | |COMMAND |->|COMMAND COSINE-->PWM|->| | |pulses | | Arduino | +---------+ +-----------+ +---------------------------+
Firmware
See attached file. This is an Arduino type .PDE file and can be compiled with the arduino development software. It does use a custom made interrupt routine, though.
Optical encoder
This is a quadrature optical encoder removed from a inkjet printer. It has built-in signal conditioning which means that it has digital outputs that can go directly to the arduino pins. They are also strong enough to drive a pair of diagnostic LEDs. These let you check the alignment of the optical strip. I use the optical strip from the same printer as the encoder, since the encoder is optimized for a certain stripe spacing.
Features
This was worth the trouble to make for the following reasons:
1. Stepper motor slips (missed steps) are immediately corrected. This means that I can use a smaller stepper than I would have otherwise been able to. It also means that I don't find an overnight print with a sideways slip in the middle of it. 2. The stepper is a lot quieter. This is because it is being driven with smoothly varying sinewaves, not abrupt square waves. 3. The stepper runs cooler. I am running a unipolar stepper in a bipolar way. This is not a unique advantage of this technique, I know, but it is an improvement in the way that I was doing things before.
