Metal Mendel
Revision as of 08:55, 18 March 2010 by Buzz (talk | contribs)
Metal Mendel RepStrap
Release status: unknown
efforts towards a metal Mendel RepStrap
Working Notes
Project Lead(s): swighton et. al. Wiki-maintainers and helpers:
Photos and Drawings
Note
Metal/Mendel is cross-fertile with Eiffel and is probably part RBS. It's one big whirling gyre of intercompatible design concepts. Forum thread: http://dev.forums.reprap.org/read.php?4,29852,29852
Files
File:Mendel Drawings.zip
Drawings
The files in Mendel_Drawings.zip are a bunch of pdfs. We need to render the pdfs as .png type image files (using image magick or pdftk?) and embed them in a series of pages. E.g. x_axis_belt_clamp.pdf is a pdf in the zip, we need x_axis_belt_clamp.png, and then either have Mendel/Drawings be one long image dump or have it be a list of pages like: Mendel/x_axis_belt_clamp
Units!
Inches
Note: swighton's original drawings are in Inches.
Metric
We will want a translation into metric for people using metric tooling.
Tooling
Description of tooling requirements.
Process
The process is depends pretty heavily on having access to a machine shop and a bunch of metal: if you are using swighton's drawings, then you can probably get by with a bandsaw, drill press, sander, and miller.
To make each part, you usually cut the stock aluminum (or whatever metal you're using) to size and drill the holes indicated by the drawings, with an occasional milled part.
Notes
Swighton's got a pretty good writeup, so he'll probably just copy it here.
