Mendel materials procurement
So what do you need and where do you get the parts?
Part quantities and suggested suppliers are in the assembly data sheet on the the Bill of Materials (BOM) tab. Please feel free to upload suggestions for supply, whether you are a supplier or a builder, by adding new columns to the spreadsheet. Be sure to add the geographical information in the column header.
From the BOM you'll see that you need to get hold of about 10 different types of materials. Before you buy anything, here is some important information you should know:
Bar
All bar is ø 8 mm diameter. Generally you can survive just fine on “Bright Zinc Plated" (BZP). BZP is better than Bright Mild Steel (BMS) as BMS will rust unless coated with oil. A2 steel will feel nicer and be straighter, but is more expensive. It is best to buy in 1m lengths and then cut to size. See the assembly data sheet for the number of 1m lengths needed.
Bearings
Mendel does not impart a big load on any of the bearings, therefore high specification bearings are not at all needed. Get the cheapest ones you can.
Belt
Make sure you get CONTI SYNCHROFLEX tooth profile, or an equivalent which allows enough room for chunky teeth. For example, HTD (round profile) does not allow enough room for teeth on a tight diameter.
RepRap attempts to print its own parts wherever possible. This includes toothed drive pulleys. 5 mm pitch (or imperial equivalent XL pitch, 0.2") belts have been investigated because at the time of research a 5 mm pitch was the most achievable to print. See the assembly data sheet for the belt specifications.
Belt need to be split to a width of 5mm. This can be achieved using the Belt splitter jig (two reprapped parts).
Extruder parts
The extruder design is frequently updated: check the Mendel extruder page for the latest procurement/preparation documentation.
Fasteners
Cheap BZP parts are fine.
Motors
Mendel has been designed to cater for either NEMA 17 or NEMA 14 specification stepper motors. Buy whichever is easier and cheaper for you. If going for the smaller NEMA 14 motors, aim for the high torque option. You need approximately 1400 g.cm of holding torque or more to be safe.
PCB/Electronics
You’ll need a fully assembled electronics kit (the assembly directions here support Generation 3 electronics). You can buy these ready assembled, or as a kit that you can solder up yourself.
Thin sheet
This is needed for the optoswitch flags. Thickness must be less than 2 mm. You will need a minimum total area of 8 cm x 5 cm. Material must be opaque to infra-red light (the optoswitch uses IR light). Material must be pliable (easy to bend into shape). Aluminium sheet is good. Some New Zealanders have been known to use beer cans, which are easy to cut with ordinary scissors...
RP
You need to get hold of a set of printed parts.
- Part files for the cartesian bot are available here.
- Part files for the Mendel extruder are available here.
Check the thumbnail for a visual glossary of all the RP parts.
A small list of commercial Rapid Prototyping Services is here, but be warned, RP bureaus generally charge extortionate rates.
Thick Sheet
Sheet must range between 4 mm - 6 mm thickness. You will need a minimum total area of 42 cm x 40 cm. Your sheet must be flat as this is what you’ll be printing on! MDF (Medium Density Fibre Board) is definitely best as it laser cuts or saws easily and is usually very flat. It is also cheap. Plywood is a good option if you require extra strength in your machine, but is harder to work with, either with a saw or a laser cutter. If using polymer make sure it is flat. Cast polymer is the flattest, but may not laser cut as well as extruded polymer. However, extruded polymer is typically not flat. When storing sheets always store them face down on a flat surface. Stacking them at an angle on their side will ruin their flatness.
Studding
All studding (i.e. threaded rod) is M8. BZP is fine. It is best to buy in 1m lengths and then cut to size. See the data sheet for required lengths.
Back to Mendel mechanical construction root.
