Mendel circuit boards
Revision as of 16:22, 9 March 2010 by Zelfje (talk | contribs) (BOM)
Mendel Build Documentation
You may find the Mendel assembly data sheet useful during assembly.
Top circuits
BOM
Total # of assemblies: 1
Name Qty/assembly Total Qty Type
motherboard-plate.par 1 1 Sheet image
extruder-controller-v2-2.par 1 1 PCB
reprap-mother-board-v1.1.par 1 1 PCB
m3-capx20.par 6 6 Fastener
m3-nut.par 12 12 Fastener
m3-nylock.par 6 6 Fastener
m3-washer.par 24 24 Fastener
Assembly
M3 nuts are used as spacers to elevate the boards slightly. This will help get your wiring neater later.
Bottom circuits
BOM
stepper-plate.par 1 1 Sheet
xlr-bracket_1off.par 1 1 RP
stepper-motor-driver-v2-3.par 3 3 PCB
usb-female-pcb.par 1 1 PCB
xlr-3-pin-male-d-type.par 1 1 Electronics
m4-nylock.par 12 12 Fastener
m4-nut.par 2 2 Fastener
m4-washer.par 52 52 Fastener
m4x16-cap.par 12 12 Fastener
m4x40-cap.par 2 2 Fastener
RP parts
Assembly
Stepper driver PCBs are elevated from the sheet by two washers.
The power and USB connections are held on by two 40mm M4 cap screws with their heads under the board pointing upwards. First secure the XLR male connector using two ordinary nuts and washers. Then add the USB board (no washers underneath) and secure that with nylocks and washers on top.
Back to Mendel mechanical construction root.
