Mendel Y-axis
Mechanical: Overview | Mendel solid model files | Procurement | Preparation of materials | Assembly notes | Extruder | X-axis | Z-axis | Y-axis | Circuit boards | Frame | Squaring the axes
You may find the assembly data sheet useful during assembly.
Motor bracket
BOM
Total # of assemblies: 1
Name | Qty/assembly | Total Qty | Type |
drive-pulley_3off.par | 1 | 1 | RP |
y-motor-bracket_1off.par | 1 | 1 | RP |
opto-endstop-v2-1-pcb.par | 1 | 1 | PCB |
m3-capx20.par | 5 | 5 | Fastener |
m3-nut.par | 2 | 2 | Fastener |
m3-nylock.par | 1 | 1 | Fastener |
m3-washer.par | 8 | 8 | Fastener |
624-bearing.par | 2 | 2 | Bearing |
m4-nylock.par | 2 | 2 | Fastener |
m4-washer.par | 6 | 6 | Fastener |
m4x40-cap.par | 2 | 2 | Fastener |
m5-mudguard-washer.par | 2 | 2 | Fastener |
stepper-motor-nema17-fl42sth47-1684A-01.par | 1 | 1 | Motor |
Printed parts
Assembly
Optoswitch pcb is spaced with two M3 nuts.
Idler bracket
BOM
y-idler-bracket_1off.par | 1 | 1 | RP |
Printed parts
Assembly
Y bearing 360
Two pairs needed, one with a ‘left’ outer and the other with a ‘right’ outer.
BOM
Total # of assemblies: 2
y-bearing-360-inner_2off.par | 1 | 2 | RP |
y-bearing-360-outer-_1off.par | 1 | 2 | RP |
624-bearing.par | 4 | 8 | Bearing |
m4-nylock.par | 6 | 12 | Fastener |
m4-washer.par | 26 | 52 | Fastener |
m4x40-cap.par | 6 | 12 | Fastener |
Printed parts
Assembly
Before this assembly it's important to understand the key mechanical concepts of how the axes work. If you haven't already, check this video out:
<videoflash type="vimeo">6982104|640|480</videoflash>
Once assembled, clamp the ‘A’ and ‘B’ bolts tight. Set the 360° fit by inserting a ø8 mm bar (e.g. Y bar) into the bearing assembly. Tighten/slacken the two lower adjuster bolts (‘C’) until smooth running is achieved. Ensure all bearings rotate when the bar is slid up and down.
Y bearing 180
BOM
y-bearing-180-inner_2off.par | 1 | 2 | RP |
y-bearing-180-outer-_1off.par | 1 | 2 | RP |
624-bearing.par | 2 | 4 | Bearing |
m4-nylock.par | 2 | 4 | Fastener |
m4-washer.par | 24 | 48 | Fastener |
m4x40-cap.par | 2 | 4 | Fastener |
Printed parts
Assembly
5 washer stack either side of bearing. Once assembled, insert a ø 8 mm bar in between the bearings and clamp the slotted bolt to achieve a smooth run. Ensure all bearings rotate when the bar is slid up and down.
Chassis
BOM
purge-plate.par | 1 | 1 | Sheet |
y-chassis.par | 1 | 1 | Sheet |
y-flag.par | 1 | 1 | Thin sheet |
y-belt-clamp_2off.par | 2 | 2 | RP |
y-bearing-180-left.asm | 1 | 1 | Assembly |
y-bearing-180-right.asm | 1 | 1 | Assembly |
y-bearing-360-left.asm | 1 | 1 | Assembly |
y-bearing-360-right.asm | 1 | 1 | Assembly |
m3-capx20.par | 4 | 4 | Fastener |
m3-nut.par | 4 | 4 | Fastener |
m3-washer.par | 4 | 4 | Fastener |
m4-nylock.par | 20 | 20 | Fastener |
m4-washer.par | 40 | 40 | Fastener |
m4x16-cap.par | 4 | 4 | Fastener |
m4x40-cap.par | 16 | 16 | Fastener |
Printed parts
Assembly
Ensure all bolt heads sit on the underside of the chassis and bolt shanks point up. This guarantees that the chassis assembly will not collide with any of the frame structure it moves in.
Put the Y-axis ground rods through the bearings before tightening them. This ensures everything is aligned.
Bed will be attached later.
Back to Mendel mechanical construction root.
