Mendel Y-axis
Revision as of 06:00, 13 October 2009 by Adrianbowyer (talk | contribs) (Protected "Mendel Y-axis" [edit=autoconfirmed:move=autoconfirmed])
You may find the assembly data sheet useful during assembly.
Motor bracket
BOM
Total # of assemblies: 1
Name Qty/assembly Total Qty Type
drive-pulley_3off.par 1 1 RP
y-motor-bracket_1off.par 1 1 RP
opto-endstop-v2-1-pcb.par 1 1 PCB
m3-capx20.par 5 5 Fastener
m3-nut.par 2 2 Fastener
m3-nylock.par 1 1 Fastener
m3-washer.par 8 8 Fastener
624-bearing.par 2 2 Bearing
m4-nylock.par 2 2 Fastener
m4-washer.par 6 6 Fastener
m4x40-cap.par 2 2 Fastener
m5-mudguard-washer.par 2 2 Fastener
stepper-motor-nema17-fl42sth47-1684A-01.par 1 1 Motor
Printed parts
Assembly
Optoswitch pcb is spaced with two M3 nuts.
Idler bracket
BOM
y-idler-bracket_1off.par 1 1 RP
Printed parts
Assembly
Y bearing 360
Two pairs needed, one with a ‘left’ outer and the other with a ‘right’ outer.
BOM
Total # of assemblies: 2
y-bearing-360-inner_2off.par 1 2 RP
y-bearing-360-outer-_1off.par 1 2 RP
624-bearing.par 4 8 Bearing
m4-nylock.par 6 12 Fastener
m4-washer.par 26 52 Fastener
m4x40-cap.par 6 12 Fastener
Printed parts
Assembly
Once assembled, clamp the ‘A’ and ‘B’ bolts tight. Set the 360° fit by inserting a ø8 mm bar (e.g. Y bar) into the bearing assembly. Tighten/slacken the two lower adjuster bolts (‘C’) until smooth running is achieved. Ensure all bearings rotate when the bar is slid up and down.
Y bearing 180
BOM
y-bearing-180-inner_2off.par 1 2 RP
y-bearing-180-outer-_1off.par 1 2 RP
624-bearing.par 2 4 Bearing
m4-nylock.par 2 4 Fastener
m4-washer.par 24 48 Fastener
m4x40-cap.par 2 4 Fastener
Printed parts
Assembly
5 washer stack either side of bearing. Once assembled, insert a ø 8 mm bar in between the bearings and clamp the slotted bolt to achieve a smooth run. Ensure all bearings rotate when the bar is slid up and down.
Chassis
BOM
purge-plate.par 1 1 Sheet
y-chassis.par 1 1 Sheet
y-flag.par 1 1 Thin sheet
y-belt-clamp_2off.par 2 2 RP
y-bearing-180-left.asm 1 1 Assembly
y-bearing-180-right.asm 1 1 Assembly
y-bearing-360-left.asm 1 1 Assembly
y-bearing-360-right.asm 1 1 Assembly
m3-capx20.par 4 4 Fastener
m3-nylock.par 4 4 Fastener
m3-washer.par 4 4 Fastener
m4-nylock.par 20 20 Fastener
m4-washer.par 40 40 Fastener
m4x16-cap.par 4 4 Fastener
m4x40-cap.par 16 16 Fastener
Printed parts
Assembly
Ensure all bolt heads sit on the underside of the chassis and bolt shanks point up. This guarantees that the chassis assembly will not collide with any of the frame structure it moves in. Bed will be attached later.
Back to Mendel mechanical construction root.
