Mendel X-axis
Revision as of 21:28, 16 March 2010 by Casainho (talk | contribs) (BOM: -- added 2 alternatives for a drive-pulley-3_off.par)
Mendel Build Documentation
You may find the Mendel assembly data sheet useful during assembly.
This diagram shows the main components of the X axis.
This shows the X axis almost completed. The opto-switch and opto-switch flags haven't been fitted, and nor have the motor, the extruder, and the toothed belt.
Carriage
BOM
Total # of assemblies: 1
Name Qty/assembly Total Qty Type
x-carriage-belt-clamp_2off 2 2 RP
x-carriage-lower_1off 1 1 RP
x-carriage-upper_1off 1 1 RP
m4-nut 12 12 Fastener
m4-nylock 10 10 Fastener
m4-washer 58 58 Fastener
m4x16-cap 6 6 Fastener
m4x40-cap 14 14 Fastener
x-flag 1 1 Thin sheet
Reprapped parts
Assembly
Before this assembly it's important to understand the key mechanical concepts of how the axes work. If you haven't already, check this video out:
<videoflash type="vimeo">6982104|640|480</videoflash>
Assemble the lower carriage first (1). Note trapped nuts.
Then assemble the upper carriage (2).
Assemble the two halves together (3) using 6 M4x40 caps (don't forget the optoflag!). Tighten the middle two caps, keep the outer two pairs loose. When fully assembled use a piece of ø8 mm bar to set the distances between the bearings. Slide the bar between the bearings and tighten/slacken the outer two pairs of M4x40 caps to achieve a smooth, low resistance, running fit.
Finally assemble the extruder (4).
Idler bracket
BOM
x-180-z-bearing-plate_2off.par 2 2 RP
x-bar-clamp-m3_6off.par 2 2 RP
x-end-bracket_2off.par 1 1 RP
m3-capx20.par 4 4 Fastener
m3-nylock.par 4 4 Fastener
m3-washer.par 8 8 Fastener
m4-nylock.par 11 11 Fastener
m4-washer.par 36 36 Fastener
m4x16-cap.par 2 2 Fastener
m4x40-cap.par 9 9 Fastener
m5-mudguard-washer.par 2 2 Fastener
624-bearing.par 6 6 Bearing
Reprapped parts
Assembly
Do not tighten the two adjuster bolts marked with a * in this diagram. These will be used to set the contact between the bearings and the Z shaft. If you attempt to tighten them now you may damage the bracket. N.B. there are 3 washers under each of the four z-axis bearings.
Vert bearing 180
BOM
z-flag.par 1 1 Thin sheet
x-axis-side-plate-nut-jig_2off.par 1 1 RP
x-bar-clamp-m4_4off.par 2 2 RP
x-vert-drive-nut-trap_4off.par 2 2 RP
x-vert-drive-side-plate-180-end_2off.par 2 2 RP
m4-nut.par 4 4 Fastener
m4-nylock.par 4 4 Fastener
m4-washer.par 16 16 Fastener
m4x40-cap.par 8 8 Fastener
m8-nut.par 1 1 Fastener
Reprapped parts
Assembly
Use the ‘side plate nut jig’ to trap the nuts for the bar clamp bolts. There is room between the jig and the side plate for washers on both sides.
Vert bearing 360
BOM
x-360-z-bearing-plate-mirror_2off.par 2 2 RP
x-360-z-bearing-plate_2off.par 2 2 RP
x-vert-drive-side-plate-360-end_2off.par 2 2 RP
opto-endstop-v2-1-pcb.par 1 1 PCB
m3-capx20.par 1 1 Fastener
m3-nylock.par 1 1 Fastener
m3-washer.par 2 2 Fastener
m4-nylock.par 14 14 Fastener
m4-washer.par 44 44 Fastener
m4x16-cap.par 4 4 Fastener
m4x40-cap.par 14 14 Fastener
Reprapped parts
Assembly
As with the Vert Bearing 180, there is room between the nut jig and the side plate for washers on both sides.
Motor bracket
BOM
x-bar.par 2 2 Bar
drive-pulley_3off.par (alternative #1 #2) 1 1 RP
x-bar-clamp-m3_6off.par 4 4 RP
m3-capx20.par 8 8 Fastener
m3-washer.par 12 12 Fastener
624-bearing.par 4 4 Bearing
m4-washer.par 12 12 Fastener
m5-mudguard-washer.par 4 4 Fastener
stepper-motor-nema17-fl42sth47-1684A-01.par 1 1 Motor
Reprapped parts
Assembly
Assembly is also compatible for NEMA 14 motors.
For all axis motors you'll need to file your own flats onto both sides of the drive shafts. There's a few essential tips for doing this:
  • Put blue-tak/tape around the base of the drive shaft to prevent alloy filings getting dragged into the bearings (the motor's magnets will try to suck them in!)
  • The flat should extend down the shaft to ~ 3mm from the face of the motor.
  • Clamp the shaft, not the motor; carefully get it parallel to the vice by eye,
  • The depth of the flat depends on your drive pulley hole profile, so have a good look before you do this.
  • Ensure flat depths are even or you'll get a wobbly drive pulley.
  • When filing, check frequently: if the flat shape is a rectangle, it's parallel to the axis; if it's a trapezium, it's not.
  • The fit should be tight so that it won't come off on its own, but not too tight or you'll split the drive pulley.
  • When pushing the drive pulley onto the motor shaft make sure the rear of the shaft is supported so that you can lightly tap the pulley with a hammer. Failure to support the back of the motor shaft will result in a broken motor.
  • While you're tooled up you may as well do all the motors in one shot.
If you wish, you can leave the motor and toothed belt off at this stage and fit them later. (Maybe like me you are waiting for the postman...) If you do this, temporarily put four M3 washers and four ordinary M3 nuts (not nylocks) on the screws that will hold the motor.
If the bars are still covered in a film of oil to prevent rusting, thoroughly wipe this off now with a paper towel or similar. (Mineral oil can damage some plastics that RepRap uses to build parts.) It will be replaced with silicone grease later.
Fit the bars. Make sure the bars do not touch the bearings.
Final x-axis assembly
BOM
x-motor-bracket 1 1 Assembly
x-motor-bracket-spacer_2off 2 2 RP
x-vert-bearing-360 1 1 Assembly
x-vert-bearing-180 1 1 Assembly
x-idler-bracket 1 1 Assembly
x-belt 1 1 Belt
x-carriage 1 1 Assembly
Reprapped parts
Assembly
Don’t tighten the belt until the x-axis is mounted on the main assembly. Lightly grease the rods with silicone grease. Silicone grease is inert as far as almost all plastics are concerned, and won't damage them.
The spacers are to get the dimensions roughly right on initial assembly. You may find, when you put the whole machine together, that they are a little short and that both their ends do not touch the neighboring parts. This is fine.
Back to Mendel mechanical construction root.
