Mendel X-axis
Carriage
BOM
Total # of assemblies: 1
Name | Qty/assembly | Total Qty | Type |
x-carriage-belt-clamp_2off | 2 | 2 | RP |
x-carriage-lower_1off | 1 | 1 | RP |
x-carriage-upper_1off | 1 | 1 | RP |
m4-nut | 12 | 12 | Fastener |
m4-nylock | 10 | 10 | Fastener |
m4-washer | 58 | 58 | Fastener |
m4x16-cap | 6 | 6 | Fastener |
m4x40-cap | 14 | 14 | Fastener |
x-flag | 1 | 1 | Thin sheet |
RP parts
Assembly
Assemble the lower carriage first (1). Note trapped nuts.
Then assemble the upper carriage (2).
Assemble the two halves together (3) using 6 M4x40 caps (don't forget the optoflag!). Tighten the middle two caps, keep the outer two pairs loose. When fully assembled use a piece of ø8 mm bar to set the distances between the bearings. Slide the bar between the bearings and tighten/slacken the outer two pairs of M4x40 caps to achieve a smooth, low resistance, running fit.
Finally assemble the extruder (4).
Idler bracket
BOM
x-180-z-bearing-plate_2off.par | 2 | 2 | RP |
x-bar-clamp-m3_6off.par | 2 | 2 | RP |
x-end-bracket_2off.par | 1 | 1 | RP |
m3-capx20.par | 4 | 4 | Fastener |
m3-nylock.par | 4 | 4 | Fastener |
m3-washer.par | 8 | 8 | Fastener |
m4-nylock.par | 11 | 11 | Fastener |
m4-washer.par | 36 | 36 | Fastener |
m4x16-cap.par | 2 | 2 | Fastener |
m4x40-cap.par | 9 | 9 | Fastener |
m5-mudguard-washer.par | 2 | 2 | Fastener |
624-bearing.par | 6 | 6 | Bearing |
RP parts
Assembly
Do not tighten the two adjuster bolts marked with a * in this diagram. These will be used to set the contact between the bearings and the Z shaft. If you attempt to tighten them now you may damage the bracket.
Vert bearing 180
BOM
z-flag.par | 1 | 1 | Thin sheet |
x-axis-side-plate-nut-jig_2off.par | 1 | 1 | RP |
x-bar-clamp-m4_4off.par | 2 | 2 | RP |
x-vert-drive-nut-trap_4off.par | 2 | 2 | RP |
x-vert-drive-side-plate-180-end_2off.par | 2 | 2 | RP |
m4-nut.par | 4 | 4 | Fastener |
m4-nylock.par | 4 | 4 | Fastener |
m4-washer.par | 16 | 16 | Fastener |
m4x40-cap.par | 8 | 8 | Fastener |
m8-nut.par | 1 | 1 | Fastener |
RP parts
Assembly
Use the ‘side plate nut jig’ to trap the nuts for the bar clamp bolts. There is room between the jig and the side plate for washers on both sides.
Vert bearing 360
BOM
x-360-z-bearing-plate-mirror_2off.par | 2 | 2 | RP |
x-360-z-bearing-plate_2off.par | 2 | 2 | RP |
x-vert-drive-side-plate-360-end_2off.par | 2 | 2 | RP |
opto-endstop-v2-1-pcb.par | 1 | 1 | PCB |
m3-capx20.par | 1 | 1 | Fastener |
m3-nylock.par | 1 | 1 | Fastener |
m3-washer.par | 2 | 2 | Fastener |
m4-nylock.par | 14 | 14 | Fastener |
m4-washer.par | 44 | 44 | Fastener |
m4x16-cap.par | 4 | 4 | Fastener |
m4x40-cap.par | 14 | 14 | Fastener |
RP Parts
Assembly
As with the Vert Bearing 180, there is room between the nut jig and the side plate for washers on both sides.
Motor bracket
BOM
x-bar.par | 2 | 2 | Bar |
drive-pulley_3off.par | 1 | 1 | RP |
x-bar-clamp-m3_6off.par | 4 | 4 | RP |
m3-capx20.par | 8 | 8 | Fastener |
m3-washer.par | 12 | 12 | Fastener |
624-bearing.par | 4 | 4 | Bearing |
m4-washer.par | 12 | 12 | Fastener |
m5-mudguard-washer.par | 4 | 4 | Fastener |
stepper-motor-nema17-fl42sth47-1684A-01.par | 1 | 1 | Motor |
RP parts
Assembly
When pushing the drive pulley onto the motor shaft make sure the rear of the shaft is supported so any shock does not travel through the bearings. Assembly is also compatible for NEMA 14 motors.
Fit bars. Make sure the bars do not touch the bearings.
Final x-axis assembly
BOM
x-motor-bracket | 1 | 1 | Assembly |
x-motor-bracket-spacer_2off | 2 | 2 | RP |
x-vert-bearing-360 | 1 | 1 | Assembly |
x-vert-bearing-180 | 1 | 1 | Assembly |
x-idler-bracket | 1 | 1 | Assembly |
x-belt | 1 | 1 | Belt |
x-carriage | 1 | 1 | Assembly |
RP parts
Assembly
Don’t tighten belt until the x-axis is mounted on the main assembly.
