Mendel X-axis
Revision as of 18:22, 11 October 2009 by Skinnyed (talk | contribs)
Carriage
BOM
Total # of assemblies: 1
Name Qty/assembly Total Qty Type
x-carriage-belt-clamp_2off 2 2 RP
x-carriage-lower_1off 1 1 RP
x-carriage-upper_1off 1 1 RP
m4-nut 12 12 Fastener
m4-nylock 10 10 Fastener
m4-washer 58 58 Fastener
m4x16-cap 6 6 Fastener
m4x40-cap 14 14 Fastener
x-flag 1 1 Thin sheet
RP parts
Assembly
Assemble the lower carriage first (1). Note trapped nuts.
Then assemble the upper carriage (2).
Assemble the two halves together (3) using 6 M4x40 caps (don't forget the optoflag!). Tighten the middle two caps, keep the outer two pairs loose. When fully assembled use a piece of ø8 mm bar to set the distances between the bearings. Slide the bar between the bearings and tighten/slacken the outer two pairs of M4x40 caps to achieve a smooth, low resistance, running fit.
Finally assemble the extruder (4).
Idler bracket
BOM
x-180-z-bearing-plate_2off.par 2 2 RP
x-bar-clamp-m3_6off.par 2 2 RP
x-end-bracket_2off.par 1 1 RP
m3-capx20.par 4 4 Fastener
m3-nylock.par 4 4 Fastener
m3-washer.par 8 8 Fastener
m4-nylock.par 11 11 Fastener
m4-washer.par 36 36 Fastener
m4x16-cap.par 2 2 Fastener
m4x40-cap.par 9 9 Fastener
m5-mudguard-washer.par 2 2 Fastener
624-bearing.par 6 6 Bearing
RP parts
Assembly
Do not tighten the two adjuster bolts marked with a * in this diagram. These will be used to set the contact between the bearings and the Z shaft. If you attempt to tighten them now you may damage the bracket.
Vert bearing 180
BOM
z-flag.par 1 1 Thin sheet
x-axis-side-plate-nut-jig_2off.par 1 1 RP
x-bar-clamp-m4_4off.par 2 2 RP
x-vert-drive-nut-trap_4off.par 2 2 RP
x-vert-drive-side-plate-180-end_2off.par 2 2 RP
m4-nut.par 4 4 Fastener
m4-nylock.par 4 4 Fastener
m4-washer.par 16 16 Fastener
m4x40-cap.par 8 8 Fastener
m8-nut.par 1 1 Fastener
RP parts
Assembly
Use the ‘side plate nut jig’ to trap the nuts for the bar clamp bolts. There is room between the jig and the side plate for washers on both sides.
Vert bearing 360
BOM
x-360-z-bearing-plate-mirror_2off.par 2 2 RP
x-360-z-bearing-plate_2off.par 2 2 RP
x-vert-drive-side-plate-360-end_2off.par 2 2 RP
opto-endstop-v2-1-pcb.par 1 1 PCB
m3-capx20.par 1 1 Fastener
m3-nylock.par 1 1 Fastener
m3-washer.par 2 2 Fastener
m4-nylock.par 14 14 Fastener
m4-washer.par 44 44 Fastener
m4x16-cap.par 4 4 Fastener
m4x40-cap.par 14 14 Fastener
RP Parts
Assembly
As with the Vert Bearing 180, there is room between the nut jig and the side plate for washers on both sides.
