Mendel User Manual/fr
General
Using RepRap
Designing things to make
Converting a simple 2D image into a printed object
See Mendel_User_Manual/Converting_a_simple_2D_image_into_a_printed_object for detailed instructions.
More
If you are designing things to be made in RepRap, Ed's guide on to how to design for FFF above may be useful. It's written for the Stratasys Dimension proprietary RP machine, but almost all of what it says is relevant to RepRap too. One difference: ignore the section on adjusting hole diameters to get them to come out right. On RepRap, if you specify a 3mm hole, it comes out as 3mm...
Rather than design things completely from scratch, you might save a bit of time by starting from something in the Available Files and tweaking it to fit your needs.
See also the Useful Software Packages to create STL models.
Mechanical
Software and Firmware
- Installing RepRap Host Software
- Configuring your RepRap
- Firmware Help
- Host Software Help
- Mendel User Manual: Host Software
Files and Formats
- RepRap G Codes - This defines all the G Codes used to communicate from the host computer to the RepRap machine.
- Java Software Preferences File
- RFO file format - Saving and loading multiple objects on RepRap's build base.
Translations of this page
Deutsch: Mendel_Gebrauchsanleitung
