Mendel Power Bracket
Revision as of 19:09, 26 July 2010 by Tbuser (talk | contribs) (Files)
GPL
Introduction
This OpenSCAD script is a derivative of the XLR Bracket model that can create either a standard XLR bracket or a coax DC power bracket slot. This way you can use a commonly available 12v 5a power brick instead of splicing an XLR connector onto your power source.
Instructions
Change plug_diameter=8 and type="COAX" in order to mount a 2.5MM DC Power Connector.
Change plug_diameter=20 and type="XLR" to generate a standard XLR bracket.
Or just download the appropriate stl file if the diameter is right for your sockets.
Files
Requires the mendel.inc and mendel.conf from the Parameterized Mendel project.
File:Power-bracket 1off.scad
Xlr-bracket 1off display large.jpg File:Xlr-bracket 1off.stl
Coax-bracket 1off display large.jpg File:Coax-bracket 1off.stl
