Mendel Drawings
Usage
Rather than machining a Mendel, you may want to make a WolfStrap.
Files
Imperial Measurements
Note: Mendel_Drawings.zip contains a number of pdfs. These pdfs are engineering drawings of mendel parts, drafted in auto cad.
Units are in Imperial - Inches.
Import Drawings
The files in Mendel_Drawings.zip are a bunch of pdfs. It may be good to convert the pdfs to .png type image files (using image magick or pdftk?) and embed them in a series of pages. E.g. x_axis_belt_clamp.pdf is a pdf in the zip, we need x_axis_belt_clamp.png, and then either have Mendel/Drawings be one long image dump or have it be a list of pages like: Mendel/x_axis_belt_clamp --WikiSysop 07:31, 21 June 2010 (UTC)
Working Notes
To understand Mendel design, started to convert SolidEdge "part" files in "dxf" and "dwg" files.
Don't know if it's the proper place and i'm a total beginner about 3D and 2D design.
Please check what i'm doing and give me some advice. Check my english too...
- File:Frame-vertex 6off.dxf
- File:Frame-vertex 6off.dwg
- File:Y-idler-bracket 1off.dxf
- File:Y-idler-bracket 1off.dwg
- File:Y-motor-bracket 1off.dxf
- File:Y-motor-bracket 1off.dwg
- File:Z-motor-bracket 1off.dxf
- File:Z-motor-bracket 1off.dwg
- File:Z-tensioner 1off.dxf
- File:Z-tensioner 1off.dwg
- more files
Usability
How do we integrate a bunch of images with our formal set of files, which is buried here: https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/mendel/mechanics/solid-models/ And is there a good way for users to upload their changes to that system?
