Mendel/Files
Revision as of 15:26, 14 August 2010 by ClothBot (talk | contribs) (Page clean-up before fleshing out Parametrized_Mendel material.)
Mendel Build Documentation
Overview
This section is non-critical for assembly, however occasionally people request Mendel's solid model files of the total mechanical assembly.
Parameterized Mendel
Parameterized_Mendel is a redraft of Mendel which will probably be called "official", to the extent that RepRap does official.
Static Mendel
The model is available in the following formats:
Wedge
The CAD files for the wedge frame used in Mendel.
Solid Edge
Please note this is not the same as Solid Works!
Available in Version 20, academic licence
All part files for the cartesian robot are available under 'cartesian-robot-m4' here. You will need to download the whole of 'cartesian-robot-m4', then search for the _SOLIDEDGE_README.txt for further instructions on opening the general assembly.
Mendel in Solid Edge Format
AOI
AOI is a free, open-source solid modelling package. Model files have only been made for the individual printed parts, which can be found here. These parts are editable in AOI. There is no general assembly in this format. Advice on using AOI for RepRap can be found here.
Mendel in AOI Format
STL
Model files have only been included for the individual printed parts. These parts are not editable (not really anyway). There is no general assembly in this format.
Official Mendel in STL Format
SolidWorks
Idaholion has translated Mendel into SolidWorks 2010 format, available here
Extruder
The CAD files for the Mendel pinch wheel extruder are stored separately (see link bellow). These are required in addition to the wedge frame CAD files to build a Mendel.
Mendel Pinch Wheel Extruder CAD Files
Elsewhere
Many people have made sets of mendel-parts on Thingiverse that can be printed at once. Some with the smaller parts holding down the larger ones against warping. 2 Examples are here and here.
There are also lots of unofficial improved and corrected parts to be found on Thingiverse.
