MPM
Revision as of 18:45, 30 December 2020 by Davide (talk | contribs)
MPM Documentation
Multifunction Printer module
Multifunction printer module, this printer has other additional uses besides the 3d printer, by changing the extruder it is possible to install the laser cutting or the cnc mill.
Cartesian Custom
Introduction
The multifunction printer module have a structure cartesian of 3D printers.
Since my childhood, my dream was to do make a robot. And a thirty age i did it succeeded. The my first robot "completed" is it a 3d printer with double extrusion nozzle and a cartesian structure. This 3d printing is composed to a two motors for Y and X axis, two motor for filaments and two motor for Z axis for balancing force during the movement. Also use a one hot plate. For the structure I have using the aluminum profiles. For all the control to 3d printing I have used a board Arduino DUE and RADDS shield using a Repetier Firmware and have a one Raspberry Pi for the remote control with Octoprinter Software.
The main goal of MPM is to create custom objects and print many other parts with a simple download. For example, my son is very happy to play with many downloadable toys on Thingiverse
To make the 3d printer, I made an effort in every night for six months. But the best reward is always to see it work
Specifications
  • Aluminum profiles: 8
  • Motor: 6 Nema stepper
  • Extruder: Chimera Hotend metal V6 Dual
  • Power Transmission: 2 Belt for X and Y axis and 2 Lead Screws
  • Hot Plate: Anycubic
  • CPU: Arduino Due with shield RADDS
  • Server: Raspberry Pi 3 with software Octoprint
  • Print Volume: 250mm x 250mm x 350mm
MPM
Manufacturer Davide Zuanon
Model MPM Cartesian
Technology FFF (Fused Filament Fabrication)/Thermoplastic extrusion
Occasional oiling = €5.
Size 562 mm (W) x 500 mm (D) x 590 mm (H) 23” (W) x 16” (D) x 23” (H)
Weight 9.0 kg 19.84lbs
Build Envelope 250 mm (W) x 250 mm (D) x 350 mm (H)
Materials PLA, ABS & more. Uses ø 3 mm filament. PLA, ABS & more. Uses ø 1/8” filament.
Nominal Speed 150mm/sec
Max Speed 300 mm/s (depending on the object to be printed)
Accuracy Diameter of nozzle 0.4 mm, - X e Y: 0,015 mm - Z: 0,39 µ
Power supply: 230 V /750 mA max
Comunication USB Cable and LAN connection ETH
Movement 4 NEMA 17 stepper motors
Extruder 2 NEMA 17 stepper motors
Video Clip
Development
History
