LulzBot/AO-101
Revision as of 20:33, 7 March 2013 by Orias (talk | contribs)
Lulzbot AO-101
Release status: Working
Truly free/libre 3D printer
GPLv3
Intro
The Lulzbot AO-101 is a tweaked version of the RepRap MendelMax 3D printer. Most of the changes made were for strength, precision, and longevity. Otherwise, the Lulzbot AO-101is very similar to the popular MendelMax build.
Here you will find more info about the printer, where you can buy one, how to get your Lulzbot printer setup and running, and version updates.
Obtaining an AO-101
Currently you can order an AO-101 from our LulzBot.com store. You can find the product page here. We ship out assembled printers usually within1 business day. Also, we only list items on our store that are currently in stock and ready to ship. With that said, you can expect to receive your printer within 5 days after completing your order (within the US).
Printer Specfications
The AO-101 is an assembled 3D printer including all of the needed hardware and electronics to print ABS and PLA plastic and Laywoo-d3 wooden 3D parts. With simple modifications it can print in polycarbonate.
Printing
  • Usable Print Area: 200mm x 190mm x 100mm (7.9in x 7.5in x 3.9in)
  • Top Print Speed: 200mm/sec (7.9in/sec)
  • Print Tolerance: 0.2mm (0.008in) in X and Y axes. Z axis is dependent on layer thickness
  • Layer Thickness: 0.075mm (0.0029in) to 0.75mm (0.029in), with included nozzles
  • Supported Materials: ABS and PLA plastic filaments
  • Usable Filament Sizes: standard 3mm (0.1in) and 1.75mm (0.007in) with included accessory and setup
Physical Dimensions
  • Overall Dimensions: 464mm x 483mm x 381mm (18.3in x 19in x 15in)
  • Weight: 8.18kg (18lbs)
Electrical
  • Power Requirements: 110 - 220 VAC, with USA power cord
  • Temperature: Maximum operating temperature (Extruder), 240C
  • Temperature: Maximum operating temperature (Heated Bed), 120C
Ships with
  • Complete documentation including a detailed manual with information for unpacking the printer, setup, downloading and using software, and starting your first print.
  • Mountable Spool Holder
  • Filament Feedtube
  • Filament Feedtube Holder
  • Startup supply of ABS filament, Natural, 3mm dia., 5lbs (2.3kg)
  • Toolkit bag
  • Allen Wrenches: 1.27mm, 2.5mm, 3mm, 4mm
  • Combination Wrenches: 5.5mm, 13mm, 18mm
  • Pliers, Needle Nose
  • Tweezers
  • X-acto Knife
  • Dental Pick
  • Flathead Bristle Brush
  • Part Removal Knife (clam knife)
  • Metric Ruler
  • PET Sheet
  • Acetone-safe Bottle (acetone not included)
  • Nozzles: 0.5mm installed, includes 0.25mm and 0.35mm nozzles
  • PTFE Tube for 1.75mm Filament
  • 90 Day Warranty
  • 1 Year Support
Configuration Files
Firmware files have the default settings configured for the LulzBot printers. The only thing you will need to change are the e-steps. The e-steps settings for you printer can be found on the printer information sheet you should have received with the printer. If you do not have this sheet, please send us a message including your printer number (p#) and we can get a copy of it to you.
