List of electronics
This page has a list of all active reprap electronics. It is still a work in progress. For a more complete list of electronics that compares features, see Comparison of Electronics.
(2012-01-18 Ruben-ikmaak: this list featured only cvommercial interests, so i at least added the real community choices, please add more info, and maybe remove the commercials)
For a list of out-of-date electronics, see List of Abandoned and Deprecated Electronics.
Community based, tested and supported electronics
RAMPS
ELECTRONICS INFO | |
Details | Description |
Arduino MEGA based modular RepRap electronics |
Features | |
Compatible Firmware | |
Where to Get Parts and/or Full Assemblies | |
Documentation/Schematics & Misc. Notes | |
Details |
Sanguinololu
Sanguinololu is a low-cost all-in-one electronics solution for Reprap and other CNC devices. It features an onboard Sanguino clone using the ATMEGA644P though a ATMEGA1284 is easily dropped in. Its four axes are powered by Pololu pin compatible stepper drivers. |
Features | |
Details |
Non-free and less tested alternatives
Generation 7
Name : Generation 7 |
Gen7 is designed as an all-in-one stand-alone board. The CPU and stepper driver chips are on the same board. The boards are designed to be replicable so that they can be cut/milled, etched DIY or printed on a reprap. |
Features | |
See Gen7's "How to get it" and Gen7 Endstop's "How to get it". | |
Details for building are on the Gen7 page. You can download the schematics which are developed using gEDA over at github. You can download them by typing: git clone https://github.com/Traumflug/Generation_7_Electronics.git |
R2C2 Electronics
R2C2 is FAST (ARM 32bits running at 100MHz!), is the new cutting edge technology that drives RepRap 3D printers at their maximum speed!!!
Please read more on the official web page: www.3DPrinting-R2C2.com |
Features | |
R2C2 firmware is a mix of the famous GRBL and TeaCup firmwares. Latest stable firmware binary file can be download here and is ready to flash using R2C2 USB bootloader. R2C2 firmware sources are on R2C2 Firmware Github. | |
The quick and easy to install R2C2 complete electronics kit for RepRap 3D Printers can be found here. | |
R2C2 Electronics documentation, support and shop on official site: www.3DPrinting-R2C2.com |
Commercial alternatives
Generation 6
Name : Generation 6 |
Gen6 electronics do not appear to be related to the original GenX designs other than by name. This is a single-board surface-mount design with the CPU and driver chips on the same board. |
Features | |
Buy from http://www.reprap-usa.com/, http://www.makemendel.com and http://www.mendel-parts.com although mendel-parts.com looks like they've been out of stock since June 2011. | |
This seems to be almost a proprietary board. If there is active development going on with these electronics I can't find it. All development seems to have stopped back in October 2010. Documentation is on the Generation 6 Electronics page. The only schematics available appear to be in zip files here. Here are some links to zip files containing modified firmwares: There does not appear to be a source code repository for schematics or firmware anywhere. Because the board uses Texas Instruments DRV8811 driver chips instead of the more common Allegro A4983-based (a.k.a. Pololu) drivers, you have to use modified versions of the more popular firmwares. That fact, in combination with the poor availability of source, does not bode well for DIY users. |
Generation 4
Name : Generation 4 |
These electronics are used for the Makerbot. They consist of an Arduino Mega shield (aka the "motherboard") and a few other boards for the stepper drivers. |
Features | |
For sale on Makerbot website at http://store.makerbot.com/electronics/assembled-electronics.html | |
Gen4 electronics consists of at least 5 separate circuit boards: the arduino shield (motherboard), 3 stepper boards and 1 extruder board. For detailed information and source code see the following links: |
