List of Firmware
Revision as of 20:40, 7 July 2011 by Bubbapizza (talk | contribs) (FiveD)
This page is an attempt to summarize ALL the firmware I can find in this gadawful mess of a wiki. From here on down is the authoritative list of firmwares:
FiveD
Author(s)
Triffid Hunter
Status
active as of June 22, 2011
Short Description
The granddaddy of all firmwares. It appears to be the original G-code interpreter from where everything is forked. Forked from Generation2
Features
  • stepper extruder
  • extruder speed control
  • movement speed control
  • RepRap-style acceleration
  • thermocouples
  • heated build platforms
Compatible Electronics
How to download
It's my understanding that as of July 6, the sourceforge repo for all official reprap stuff is getting switched over to github so for now, it can be checked out from sourceforge by running the command:
svn co https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/software/firmware
or to check it out from github, run:
git clone https://github.com/reprap/firmware.git
The firmware is in the FiveD_GCode Directory
Documentation & Misc. Notes
Documentation is over at Microcontroller firmware installation
Someone says there are preconfigured sources on the Gen7 page but I don't see any. A link would be helpful here.
Tonokip
Author(s)
johnnyr
Status
updates up to January, 2011
Short Description
Tonokip is a firmware rewrite based off of the Hydra-mmm firmware.
Features
  • Same as FiveD???
  • Can read SD cards???
How to download
The real repository appears to be downloadable by running
git clone https://github.com/johnnyr/Tonokip-Firmware.git
HOWEVER, for some reason, it's also in a subfolder along with the FiveD firmware. So it looks like you can run
and the firmware is in the Tonokip_Firmware Directory
Appears to have been forked off as Sprinter firmware
Sprinter
Authors
Kliment, caru, tonok, tesla893
Status
Active as of July 5, 2011
Short Description
forked from Klementkip. Seems to be a popular firmware
Features
  • SD card reader
  • stepper extruder
  • constant or exponential acceleration
How to download
Can download like this:
git clone https://github.com/kliment/Sprinter.git
Only documentation seems to be over at Sprinter
  • Was formerly called Klimentkip/caruKlip
  • Supposedly aka Tesla but I can't find any references in the wiki to that
  • thermocouples are experimental
Teacup
Authors
Triffid_hunter, Traumflug, jakepoz
Status
Short Description
This was a complete rewrite of the FiveD firmware to optimize it for Arduino's wimpy 8-bit CPU
Features
  • Has better performance due to
  • written in C instead of C++
  • only uses integer math
  • minimizes long math interruptions
  • stepper extruder
  • start-stop ramping
  • thermocouples
How to download
git clone https://github.com/triffid/Teacup_Firmware.git
Documentation and more information is over at github and on the wiki under Teacup Firmware.
Supposedly there are the instructions on the Gen7 electronics page on how to get Teacup installed but I can't find them. A link would be helpful here.
  • this firmware was ported to ARM Cortex-M3 for the HBox_RepRap_Electronics.
  • DC motor control is present but untested
  • contains a constant acceleration implementation based on this article
Makerbot
Author(s)
Who knows
Status
active as of Jun 29, 2011
Short Description
The v2 makerbot firmware is a rewrite of the old Gen3 firmware to be a little more robust.
Features
How to download
Download from Makerbot's github repo using the commands
git clone https://github.com/makerbot/G3Firmware.git
The v2 firmware is where all active development takes place. See the Makerbot wiki for details on how to build and install the code.
Generation3
Author(s)
Who knows
Status
likely dead
Short Description
This appears to be a dead branch of firmware. The firmware date is 2008-08-05
Features
  • can support SD cards
How to download
Version 1.2 appears to be the last version and it's in a zip file here.
The only mention of Gen3 firmware is in the wiki at Generation3Firmware
  • documentation for the communications between host PC and electronics is in a Google Doc
Generation2
Author(s)
Who knows
Status
superceded by FiveD firmware?
Short Description
This appears to be an early prototype of the FiveD firmware
Features
unknown
How to download
All the links for this firmware are dead. It is probably buried somewhere in the past of the reprap FiveD repository
Documentation appears to be at Generation2Firmware
Klementkip
Author: Kliment
Status
superceded by Sprinter
Short Description
This was originally a fork of Tonokip but is now called Sprinter
Features
unknown
How to download
You can still download from Kliment's github repository by running
git clone https://github.com/kliment/Klimentkip.git
Can't find any documentation and the firmware is officially defunct now
Gen2OnABoard
Author(s)
Nick McCoy
Status
stale since Aug 2010
Short Description
This is an experimental fork of FiveD for the Gen2OnABoard electronics. May not actually work.
Features
  • stepper extruder
How to download
Downloadable from github by running:
Documentation is non existent
Hydra-MMM
Author(s)
Clayton Webster
Status
stale as of May 2010
Short Description
Hydra is a multi-headed manufacturing machine that was originally being designed and built for ME463 (senior design) at Purdue University.
Features
  • used for multi-headed machine
How to download
Downloadable from sourceforge in a zip file
The only documentation is on the wiki under Hydra-MMM Software and Firmware
Grbl
Author(s)
Simen Svale Skogsrud
Status
active up to Feb 2011
Short Description
Grbl is a no-compromise, high performance, low cost alternative to parallel-port-based motion control for CNC milling. Does not control extruders.
Features
  • run on a vanilla Arduino (Duemillanove/Uno) as long as it sports an Atmega 328
  • nice simple controller for CNC milling
  • written in tidy, modular C
  • does not require parallel port
  • able to maintain more than 30kHz step rate and delivers a clean, jitter free stream of control pulses.
  • full acceleration-management with look ahead planner
How to download
git clone [email protected]:simen/grbl.git
Documentation is at http://dank.bengler.no/-/page/show/5471_gettinggrbl
From the website:
We have limited g-code-support by design. Grbl support all the common operations encountered in output from CAM-tools, but leave human g-coders frustrated. No variables, no tool offsets, no functions, no arithmetic and no control structures. Just the basic machine operations. We have yet to find a CAM-generated file that failed to run, though.
  • No gui, all interaction is through command line
