List of Abandoned and Deprecated Firmware
Revision as of 16:56, 5 February 2013 by Pietr (talk | contribs) (Added Yarf)
This page holds a list of all abandoned, deprecated and/or out-of-date firmware.
For firmware that is currently active and being developed, see List of Firmware
Yarf
FIRMWARE INFO
Details Description
Author(s) : Pietr
Status : deprecated as of March 2012 (so much to do, so little time...)
Yarf doesn't have (m)any revolutionary features compared to recent firmwares such as Marlin or Sailfish. However, because there is extensive source code documentation, the firmware can be interesting for anyone interested in lookin at the 'inner workings' of a RepRap firmware. Moreover, the firmware might be a good base to start from if you want to develop a new firmware feature but do not want to start from scratch.
Features
  • True linear acceleration and deceleration
  • A lookahead algorithm (based on grbl)
  • Includes Matt Roberts' advance algorithm
  • PID temperature control
  • Runs on common 8-bit MCU's such as the ATmega644p and ATmega1284p
  • Direct support for thermistor tables generated by tltgen
  • Fast enough to drive four 1.8 degree stepper motors with 1/16th microstepping
  • Extensive source code documentation
Compatible Electronics
  • Only a custom electronics board developed by Pietr is fully supported
  • Should be compatible with commonly used boards such as Gen 7 and RAMPS
  • Please let the developer know if you're trying to get this running on your own electronics
How to download
Yarf on Google code
Documentation & Misc. Notes
The Yarf wiki page
Source code documentation
FiveD
FIRMWARE INFO
Details Description
Author(s) : Buzz and others
Status : active as of Sept 28, 2011
The granddaddy of all firmwares. It appears to be the original G-code interpreter. Forked from Generation2. The reason it's called FiveD is because it controls 5 dimensions: X, Y, Z, Feedrate, and Extrusion rate.
Features
  • stepper extruder
  • extruder speed control
  • movement speed control
  • RepRap-style acceleration
  • thermocouples
  • heated build platforms
How to download
The firmware is now hosted on Github. To check it out from github, run:
git clone https://github.com/reprap/firmware.git
The firmware is in the FiveD_GCode Directory
Documentation is over at Microcontroller firmware installation
Preconfigured sources for Gen7 hardware are on the Gen7_Board_1.2 page.
Hydra-MMM
FIRMWARE INFO
Details Description
Author(s) : Clayton Webster
Status : stale as of May 2010
Hydra is a multi-headed manufacturing machine that was originally being designed and built for ME463 (senior design) at Purdue University.
Features
  • used for multi-headed machine
How to download
Downloadable from sourceforge in a zip file
The only documentation is on the wiki under Hydra-MMM Software and Firmware
Generation 2 firmware
FIRMWARE INFO
Details Description
Name : Generation 2 firmware
Author(s) : Who knows
Status : superceded by FiveD firmware
This appears to be an early prototype of the FiveD firmware
Features
unknown
How to download
All the links for this firmware are dead. It is probably buried somewhere in the past of the reprap FiveD repository
Documentation appears to be at Generation2Firmware
Gen2OnABoard
FIRMWARE INFO
Details Description
Author(s) : Nick McCoy
Status : stale since Aug 2010
This is an experimental fork of FiveD for the Gen2OnABoard electronics. May not actually work.
Features
  • stepper extruder
How to download
Downloadable from github by running:
Documentation is non existent
Generation 3 firmware
FIRMWARE INFO
Details Description
Name : Generation 3 firmware
Status : likely dead
This appears to be a dead branch of firmware. The firmware date is 2008-08-05
Features
  • can support SD cards
How to download
Version 1.2 appears to be the last version and it's in a zip file here.
The only mention of Gen3 firmware is in the wiki at Generation3Firmware
  • documentation for the communications between host PC and electronics is in a Google Doc
Tonokip
FIRMWARE INFO
Details Description
Author(s) : johnnyr
Status : superceded by Sprinter
Tonokip is a firmware rewrite based off of the Hydra-mmm firmware.
Features
  • Same as FiveD???
  • Stepper extruders
How to download
The real repository appears to be downloadable by running
git clone https://github.com/johnnyr/Tonokip-Firmware.git
HOWEVER, for some reason, it's also in a subfolder along with the FiveD firmware. So it looks like you can run
and the firmware is in the Tonokip_Firmware Directory
Appears to have been forked off as Sprinter firmware. This firmware is recommended by Makergear for their Prusa Mendel kit, which runs RAMPS.
Klimentkip
FIRMWARE INFO
Details Description
Author(s) : Kliment
Status : superseded by Sprinter
This was originally a fork of Tonokip but is now called Sprinter
Features
unknown
How to download
You can still download from Kliment's github repository by running
git clone https://github.com/kliment/Klimentkip.git
Can't find any documentation and the firmware is officially defunct now
Firmware build process which documents the process for Darwin hardware using the PIC 16F648 in Generation 1 Electronics.
