Kettle Hat Hot End
Revision as of 11:22, 18 December 2011 by Theodleif (talk | contribs)
Kettle Hat Hot End
Release status: Experimental
Acorn type hot end
unknown
The kettle hat hot end is a DIY hotend intended for those who don't have a lathe.
At first you need a M6 acorn nut made of brass (DIN 1587) with a 0.5mm hole at the top, a 40 mm long M6 rod made of stainless steel with a drilled trough hole of 3.2 mm, a washer with 30 mm diameter, and an M6 nut.
There are 3 types of holes in the washer: 8 mm, 3 mm and 2mm.
Now assemble the parts:
Wind insulated nichrome wire around the base of the acorn nut and fixate a termistor to the nut. Insulate the wire with silicone tube.
Now take a second washer and omit the 2 mm holes. Instead of 8mm the big hole has a diameter of 9.5 mm this time.
Assemble it in front of the first washer.
