Input & output files using POISSON suite
Revision as of 06:34, 26 November 2011 by Glenn (talk | contribs) (+ Category:Software)
Program name input files output files
Program....................Input files.........................................................Output files
Automesh,.....XXXX.AM, or XXXX.IN XXXX.T36...............................OUTAUT.TXT, XXXX.T35, (TAPE36, TAPE37)
Autofish.....XXXX.AF, XXXX.T36, XXXX.SEQ.......................................OUTAUT.TXT, OUTFIS.TXT, XXXX.T35, XXXX.SFO, XXXX.PMI, (TAPE36, TAPE37, TAPE40)
Fish....... XXXX.T35........................................................................ OUTFIS.TXT, FishScan.TBL , XXXX.T35, (TAPE40)
CFish.......XXXX.T35 ......................................................................... OUTFIS.TXT, FishScan.TBL , XXXX.T35, (TAPE40)
Poisson...XXXX.T35..........................................................................OUTPOI.TXT, OUTPOI.TBL, XXXX.T35, XXXX.PO7, EFLD.QKP, BFLD.QKP
Pandira.....XXXX.T35, ...................................................................... OUTPAN.TXT, OUTPAN.TBL, XXXX.T35, XXXX.PA7, EFLD.QKP, BFLD.QKP, (TAPE40)
SFO.........XXXX.SEG XXXX.T35........................................................ Transit.TBL, TBETA.TBL, XXXX.T35, XXXX.SFO, XXXX.PMI, TBETAnn.TBL
SF7...........XXXX.IN7, XXXX.T35 ................................................................OUTSF7.TXT, XXXX.nn.TBL, XXXXnn.EGN, XXXXnn.T7
Force........XXXX.FCE, XXXX.T35................................................................OUTFOR.TXT
WSFplot....XXXX.T35, (WSFplot.PRF), CurveFile....................................... OUTWSF.TXT, WSFplot.PRF, numerous hardcopy graphics file types
SegField...Filename.SGF, Filename.SFO as named in SGF file..................Tablplot file named in the input SGF file
SFOtable...Filename.SFT, series of files .................................................... Filename.SFO as named in SFT file Tablplot file named in the input SFT file
SF8...Filename.IN8, two T35 solution files as named in IN8 file.......................OUTSF8.TXT
List35.........XXXX.T35 ...................................................................................XXXX.TXT
Quikplot.....Filename.QKP ............................................................................numerous hardcopy graphics file types
Tablplot.......Filename.TBL...............................................................................numerous hardcopy graphics file types
ABCfish Filename00.ABC, where ABC stands for CCL, DTL, etc.......................Filename01.ABC, Filename00.LOG, plus files XXXX.AM, XXXX.T35, XXXX.SFO for each problem solved. May also include XXXX.PMI files.
