In Situ Formation of Substrate Release Mechanisms for Gas Metal Arc Weld Metal 3-D Printing
By Michigan Tech's Open Sustainability Technology Lab.
Wanted: Students to make a distributed future with solar-powered open-source RepRap 3-D printing and recyclebot recycling. |
This page is part of an international project hosted by MOST to use RepRap 3-D printing to make OSAT for sustainable development. Learn more.
Research: Open source 3-D printing of OSAT • RecycleBot • LCA of home recycling • Green Distributed Recycling • Ethical Filament • LCA of distributed manufacturing • RepRap LCA Energy and CO2 • Solar-powered RepRaps • solar powered recyclebot • Feasibility hub • Mechanical testing • Lessons learned • MOST RepRap Build Make me: Want to build a MOST RepRap? - Start here! • Delta Build Overview:MOST • Athena Build Overview • MOST metal 3-D printer • Humanitarian Crisis Response 3-D Printer |
Source
Amberlee S. Haselhuhn, Bas Wijnen, Gerald C. Anzalone, Paul G. Sanders, Joshua M. Pearce, In Situ Formation of Substrate Release Mechanisms for Gas Metal Arc Weld Metal 3-D Printing. Journal of Materials Processing Technology. 226, pp. 50–59 (2015) DOI: 10.1016/j.jmatprotec.2015.06.038 open access
Abstract
This study provides an in-depth investigation into low-cost and no-cost substrate release mechanisms that allow gas metal arc weld 3-D printed ER4043 aluminum and ER70S-6 steel parts to be removed from a reusable print substrate with minimal energy. Aluminum oxide, boron nitride, and titanium nitride coatings were evaluated as possible substrate release agents for aluminum printing. Additionally, the in situ formation of substrate release agents such as intermetallics and oxides were tested for both aluminum and steel printing. Testing was performed with a modified Charpy impact tester to remove 3-D printed metal parts from an 1100 aluminum or A36 low carbon steel print substrate to assess the impact energy required for removal. Specimen porosity was measured prior to sectioning and microstructural analysis, hardness traverses were measured across the specimens, and the elastic and shear moduli of the parts were analyzed via ultrasonic methods. All of the employed substrate release mechanisms minimized weld penetration and, in some instances, formed a brittle phase with the print substrate that allowed the specimens to be removed with minimal impact energy. These results thus provide methods with the removal of metal 3-D printed parts from print substrates with no specialized tooling or equipment conducive to distributed manufacturing.Highlights
- In-depth investigation into low-cost and no-cost substrate release mechanisms.
- Allows gas metal arc weld 3D printed ER4043 aluminum, ER70S-6 steel removal.
- Reusable print substrate with minimal energy and no tools.
- Studied aluminum oxide, boron nitride, and titanium nitride coatings.
- In situ formation of substrate release agents such as intermetallics and oxides.
Keywords
3-D printing; additive manufacturing; aluminum; steel; in situ formation; distributed manufacturing; gas metal arc weld; GMAW; metal processing; metal inert gas welding; MIG welding; open-source; open-source electronics; open-source hardware; personal fabrication; rapid prototyping
See Also
- Open-source metal 3-D printer
- MOST open-source metal 3-D printer v2
- Applications of Open Source GMAW-Based Metal 3-D Printing
- Slicer and process improvements for open-source GMAW-based metal 3-D printing
- Substrate Release Mechanisms for Gas Metal Arc Weld 3D Aluminum Metal Printing - how to get your print off the substrate with a hammer
- Aluminum substrate cleaning for 3-D printing:MOST
- Low-cost Open-Source Voltage and Current Monitor for Gas Metal Arc Weld 3-D Printing
- Integrated Voltage—Current Monitoring and Control of Gas Metal Arc Weld Magnetic Ball-Jointed Open Source 3-D Printer
- 3D Metal Printing Slicer Plugin
- Open-source Lab
- Open source 3-D printing of OSAT
- Life-cycle economic analysis of distributed manufacturing with open-source 3-D printers
- Environmental impacts of distributed manufacturing from 3-D printing of polymer components and products
- Building research equipment with free, open-source hardware
- Delft University of Technology - MIG+ Prusa I3
- Weld 3D - 1st commercial spin off
- see literature on "wire arc additive manufacturing" (WAAM)
In the News
- Michigan Tech Opens Up Reusable Substrates for Metal 3D Printing - 3D Printing Industry
- Researchers Solve Major Issue Surrounding Metal 3D Printing With Reusable Substrates - 3D Print
- New research into gas metal arc weld 3D printing unveils easier part removal techniques - 3Ders
- Researchers solve key problem surrounding metal 3D printing - Australian Manufacturing
