How to Build a Mendel
Revision as of 09:04, 1 July 2011 by Bubbapizza (talk | contribs) (says mm right on the print)
Have a look at the suppliers in the Mendel Buyers Guide and follow the instructions.
You can also take a look at Mendel Build Manual which is horribly unorganized.
If you don't have a Mendel and are good with making stuff out of wood or steel, then here are some blueprints for the printed Mendel parts. All measurements are in mm and the little circle thing with a line through it means diameter of the hole???
