Heavy Mendel
Revision as of 13:54, 21 February 2013 by Petrus (talk | contribs)
Heavy Mendel, a self replicating 3D printer/mill/PCB engraver
The design is inspired by the triangular frame of the reprap mendel, It will be heavier and more rigid to be able to mill plastic, engrave circuit board and print at high speed. Differences compared to the standard mendel :
  • vertical X axis to quickly change the tool (extruder or spindle)
  • M10 and M12 threaded rods instead of M8 for better frame stiffness
  • 10mm smooth rods instead of 8mm for better axis stiffness
  • Precision doubling belt configuration inspired by Madkite's design : http://www.thingiverse.com/thing:8852
  • nema23 steppers for the X and Y axis instead of nema17
  • Each axis will be equipped with 4 printed linear bearings : http://www.thingiverse.com/thing:16946
Cable drive system
3D Files
stl files
sketchup files
Electronics
Stepper driver
soft start
axis panel
extruder panel
probe
extruder switch
RC servo driver
temperature controller
extruders and fans power stage
Bed and aux power stage
Extruder
The heater is made from an M6 insert with the external thread removed :
The tip is an acorn nut drilled with a 0,5mm drill-bit and hammered to reduce the hole size :
To keep the entrance of the hot-end cold, an assembly of aluminum plates and brass nuts forms a heat sink :
Heated Bed
It is built from 3mm glass, 10mm thick cork, small nails and for heating element, copper wire from a stepper motor found in an old printer.
Details :
The bed didn't heat-up enough on 12V if I connect it on the two sides, so I made the connexion between the center an the sides. It heats-up to 120°C on 12V, maybe higher if I didn't set the safety cutoff temperature at 120°C.
Small PCB 10x10cm heated bed :
http://reprap.org/wiki/File:Heavy_Mendel_heat_bed_100x100.pdf http://reprap.org/wiki/File:Heavy_Mendel_heat_bed_100x100.svg
Accessories
chuck
hobbing tool
Heavy Mendel RepRap discussion forum
