HackerBot XY system
Revision as of 09:13, 23 May 2016 by Balestrino (talk | contribs) (XY Shafts)
HackerBot Documentation
Support plates
Support plates drawings
qty part name description/notes
1 Front right support plate File:Support plate 50x50 L.80mm Front-Right.PDF
1 Front left support plate File:Support plate 50x50 L.80mm Front-Left.PDF
1 Back right support plate File:Support plate 50x50 L.140mm Back-Right.PDF
1 Back left support plate File:Support plate 50x50 L.140mm Back-Left.PDF
Back Right support plate
6 M6x12 Hex screw
6 M6 T-Nut Misumi HNTF6-6 or Bosch 3842501753
Back Left support plate
1 Back Left support plate
6 M6x12 Hex screw
Front Right support plate
1 Back Right support plate
4 M6x12 Hex screw
4 M6 T-Nut Misumi HNTF6-6 or Bosch 3842501753
Front Left support plate
1 Front Left support plate
4 M6x12 Hex screw
Support plate assembly
Cubic Slider
Cubic Slider
4 Cubic slider
8 Cubic slider belt clamp
16 M3x12 screws screw + washer + nut
4 Cubic slider bushing 12mm outside diameter, 8mm internal diameter
Assemble the cubic sliders:
XY Shafts
XY Shafts
2 Shaft 8mm. length 465mm PSFJ8-465
2 Shaft 8mm. length 438mm PSFJ8-438
8 GT2 20 tooth pulley (8mm bore)
8 XY Shim File:XY Shim.pdf
8 608ZZ Bearings outer diameter: 22mm, inner: 8mm, thickness: 7mm
8 Bearing housing Aluminum or 3D printed: File:Bearing Housing.stl
32 M3x14 screw kit fixes the bearing supports with the plates
Using the cubic sliders assemble the shafts as in photo:
double check:
  • the correct orientation of Cubic sliders
  • shafts should not be touching the Supports plate
  • Cubic sliders should be running well on the shafts, and shafts should turn easily
DON'T tighten the screws.
XY Assembly
XY Belts
4 GT2 open belt length 830mm XY core belts
Assembly the XY system with four belts like as show below:
DON'T tighten the belts.
XY Motors
XY Motors
2 Stepper motor Nema 17 2.5A shaft 5mm
2 GT2 20 teeth pulley 5mm bore
2 GT2 20 teeth pulley 8mm bore
8 M3x12 screw + washer
1 GT2 closed belt 77 teeth
1 GT2 closed belt 66 teeth
2 nema17 gasket
Y Motor (right side)
Use a GT2 closed belt 66 teeth:
X Motor (backside)
Use a GT2 closed belt 77 teeth:
Head assembly
Head
2 Shaft 8mm length 370mm Head shaft
1 Compact bowden head kit optional
1 Direct drive extruder optional
Direct driver type extruders
Head
1 Direct drive body
1 Direct drive idler
1 Direct drive holder
1 spring
1 bearing
1 11mm geared pulley
1 nema17 2.5A motor
3 M3x6 low head main body part
1 M4x20 + washer idler part
2 M3x20 holder part
1 M4x10 sping holder
1 M4x10 bearing part
1 M3x8
1 Cable holder
Head Fan
1 Fan 40x10
1 Fan holder
1 Fan duct
4 M3x8
4 M3x20 + washer + nut
Bowden type extruders
Place the head assembly AND take care to not bend shafts when mounting it:
** XY COMPLETE **
** GO TO >> HackerBot Z system **
