HIPS
Revision as of 17:19, 2 December 2022 by DavidCary (talk | contribs) (suggest merge)
You might also want to look at HIPS and d-lemonene, D-Limonen . Perhaps some or all of that page should be merged into this page. (Discuss)
High Impact Polystyrene (HIPS) is a great support material for ABS parts as it is very similar to ABS in its properties (read more at Wikipedia), but works with different solvents (Limonene for HIPS vs acetone for ABS). Experiments are ongoing for HIPS as a support material due to Limonene not affecting ABS, and a similar cost (vs double for PVA). HIPS can be easily torn from the ABS leaving an even finish behind. Also, HIPS is soluble in chemical called Limonen, which doesn't affect ABS. It can take between few hours and 2 or 3 days to dissolve the support. If possible, shake it some in a while so the soft support detaches from the model.
Known vendors
123inkt.nl 3D2PRINT 3ddirect 3Dfilamenta 3D Inkspot 3DPartistry
3D-Prima Cubic-Print Filament & meer GizmoDorks LulzBot Maker Geeks
MatterHackers meXhibit Plabs 3D Printer Playground ReprapWorld SainSmart
Subassembly India Thingibox ToyBuilder Labs 3D-Grottan.se 3DMarkt.at RepRap PT
Links
ABS - HIPS - PEEK - PEHD - PLA - PTFE - PVA - SB
