HIPS
Revision as of 03:18, 28 October 2015 by 3D-Grottan.se (talk | contribs)
High Impact Polystyrene (HIPS) is a great support material for ABS parts as it is very similar to ABS in its properties (read more at Wikipedia), but works with different solvents (Limonene for HIPS vs acetone for ABS). Experiments are ongoing for HIPS as a support material due to Limonene not affecting ABS, and a similar cost (vs double for PVA). HIPS can be easily torn from the ABS leaving an even finish behind. Also, HIPS is soluble in chemical called Limonen, which doesn't affect ABS. It can take between few hours and 2 or 3 days to dissolve the support. If possible, shake it some in a while so the soft support detach from the model.
Known vendors
123inkt.nl 3D2PRINT 3ddirect 3Dfilamenta 3D Inkspot 3DPartistry
3D-Prima Cubic-Print Filament & meer GizmoDorks LulzBot Maker Geeks
MatterHackers meXhibit Plabs 3D ReprapWorld SainSmart Subassembly India Thingibox
ToyBuilder Labs 3D-Grottan.se
Links
