Gen7 Endstop 1.3.1
Revision as of 17:10, 16 May 2011 by Traumflug (talk | contribs) (Created page with '{{Gen7Endstop}} {{Development |name = Gen7 Endstop |status = working |image = Gen7_Layout.png |description = Part of Generation 7 Electronics |license = GPL v2 |author = Traumf…')
Gen7 Endstop History   --   Gen7 Endstop is part of Generation 7 Electronics
Gen7 Endstop
GPL v2
(none)
How to get it
PCBs
Get Gen7 Endstop PCBs from Traumflug.
As Gen7 is designed to be manufactured on a RepRap, you can make PCBs yourself, of course. How to do this on a RepRap or a general milling machine is described later on this page. You want one "Gen7Board" PCB and up to six "Endstop" PCBs.
Yet another way is to purchase from one of the many houses specialized in manufacturing prototype PCBs. Gen7 is single sided, so this won't cost a fortune.
Electronic components
Get Gen7 Endstop Components Kits from Traumflug.
If you want to assemble the collection yourself, see the #Parts List section.
Parts List
Name Count Designations Vendors Remarks
Resistor 180 Ohms 1 R1 Reichelt Völkner Farnell RS
Resistor 1 kOhms 1 R2 Reichelt Völkner Farnell RS
Resistor 2.2 kOhms 1 R3 Reichelt Völkner Farnell RS
LED 3 mm Red 1 LED1 Reichelt Völkner Farnell RS
Photointerrupter TCST1103 1 U1 Reichelt Farnell RS This one is without mounting flange.
Alternative Photointerrupter TCST2103 1 U1 Reichelt Völkner Farnell RS This one has a mounting flange which might help mounting.
Molex KK100 3 Pin Header 1 CONN1 Reichelt RS Reichelt are tested to be fully compatible with Molex
Cable Connector for the above 1 Reichelt RS
Crimp Contact for the above 3 Reichelt RS
Assembly Instructions
  • To find out which components to put where, have the layout on your PC screen available.
  • PCBs fabricated with Voronoi paths need more heat, so raise your soldering iron's temperature by about 20 deg Celsius.
  • Start with the flattest parts, usually wire bridges or resistors. This way, components won't fall out when you lay the PCB on it's front for soldering. Then continue with parts of raising height, connectors are usually among the last ones.
  • To ease soldering jumper headers and similar components, put a small drop of cyanacrylate glue onto the component side before inserting them. As the PCB is single-sided, this won't hurt the solder point.
Opto Endstop
Gen7 Endstop Gen2-3 Compatible Front.jpeg Gen7 Endstop Gen2-3 Compatible Back.jpeg (pictures show an older version)
  • Take care to not overheat the photo sensor. Solder one pin on each side, then make a pause of a minute before continueing.
  • As LEDs have to be inserted the right way, they have legs of different length. The longer leg (+) goes into the hole closer to the photo sensor, the shorter one (-) into the hole closer to the border.
Setup
TBD
