Gen6 SD
Revision as of 17:47, 29 September 2012 by Ahmetcemturan (talk | contribs) (Created page with 'Kliments SD Ramps works with Gen6. This is how to connect the cables. [http://i.imgur.com/3JeYu.jpg] And thats the pins: (taken form my currrently running Marlin FW) if MO…')
This is how to connect the cables. [1]
if MOTHERBOARD == 5 || MOTHERBOARD == 51 #define KNOWN_BOARD 1 #ifndef __AVR_ATmega644P__ #ifndef __AVR_ATmega1284P__ #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu. #endif #endif //x axis pins #define X_STEP_PIN 15 #define X_DIR_PIN 18 #define X_ENABLE_PIN 19 #define X_MIN_PIN 20 #define X_MAX_PIN -1 //y axis pins #define Y_STEP_PIN 23 #define Y_DIR_PIN 22 #define Y_ENABLE_PIN 24 #define Y_MIN_PIN 25 #define Y_MAX_PIN -1 //z axis pins #define Z_STEP_PIN 27 #define Z_DIR_PIN 28 #define Z_ENABLE_PIN 29 #define Z_MIN_PIN 30 #define Z_MAX_PIN -1 //extruder pins #define E0_STEP_PIN 4 //Edited @ EJE Electronics 20100715 #define E0_DIR_PIN 2 //Edited @ EJE Electronics 20100715 #define E0_ENABLE_PIN 3 //Added @ EJE Electronics 20100715 #define TEMP_0_PIN 5 //changed @ rkoeppl 20110410 #define TEMP_1_PIN -1 //changed @ rkoeppl 20110410 #define TEMP_2_PIN -1 //changed @ rkoeppl 20110410 #define HEATER_0_PIN 14 //changed @ rkoeppl 20110410 #define HEATER_1_PIN -1 #define HEATER_2_PIN -1 #if MOTHERBOARD == 5 #define HEATER_BED_PIN -1 //changed @ rkoeppl 20110410 #define TEMP_BED_PIN -1 //changed @ rkoeppl 20110410 #else #define HEATER_BED_PIN 1 //changed @ rkoeppl 20110410 #define TEMP_BED_PIN 0 //changed @ rkoeppl 20110410 #endif #define SDPOWER -1 #define SDSS 17 #define LED_PIN -1 //changed @ rkoeppl 20110410 #define FAN_PIN -1 //changed @ rkoeppl 20110410 #define PS_ON_PIN -1 //changed @ rkoeppl 20110410 #define KILL_PIN -1 //changed @ drakelive 20120830 //our pin for debugging. #define DEBUG_PIN 0 //our RS485 pins #define TX_ENABLE_PIN 12 #define RX_ENABLE_PIN 13 #endif
