Galileo
Revision as of 13:28, 7 January 2012 by Lory90sw (talk | contribs) (Perche una nuova stampante??)
RepRap Galileo
RepRap Galileo 0.1
GPL v2
The RepRap 3D printer Galileo is a 3d printer open source designed by an Italian team-Team Kent's Strapper .It' s a derivated work from the model of the RepRap Prusa from which the movement of the axes X, Y, Z but have been substantial changes that have allowed achieve greater print area and a lower cost of implementation
Index
Kent's Strapper team opened in the city of Florence, the first Italian center RepRap area in which both the store and the exhibition center: RepRap exposed are Huxley, Prusa, Mendel and Rapman addition to the model of analysis of their implementation Archimede.Analaysing the structures of the previous RepRap printers and derivatives, they started to tought to develop a new model called Galileo in honor of the great italian scientist
Stampante 3d Galielo by Kent's Strapper
Why a new printer??
We have to say what it was build a new printer
The Premises
The RepRap Prusa has an intuitive design and a system of simple and easy assembly, the plastic parts that make up the structure are easy to handle and require no great difficulty in mounting them with the mechanical structure, and allow to obtain results even without linear bearings and other benefits . The final structure is solid and makes it easy to transport thanks to low weight.
Bigger Dimension
The first step was to increase the size in proportion to the structure particularly with regard to measures that would be poured on cinghie.La structure has been developed in such a manner so as to have more space to print.
Cheaper Structure
Another significant change has affected the mechanical structure of the new printer.It was find a new structure that could use a smaller number of pieces and always have solidità.Similar to the mechanical also plastic parts have also been modified where possible or completely renovated. all this has led to savings in economic terms but also in terms of time required to assemble the printer itself
Open Design
The structure of the new printer is made to have an open design that allow subsequent changes in every part, also the X-cart which moves the extruder-it was so designed as to be universal and can be used with any type of extruder .The 'print area is easily accessible for a heated bed or in order to analyze the subject in print a
The Plastics Part can be downloaded here: LINK
Elettronica
The model does not have a particular electronics because it is compatible with all types of those on the market, what are the changed are the STEP_FOR_MM
Benefici Del Modello:
  • Modello facile e veloce da assemblare
  • Pezzi plastici intuitivi: facili da assemblare e stampare
  • Numero barre filettate inferiore
  • Numero barre liscie inferiore
  • Quantità bulloneria inferiore
  • Cinghie più corte
  • Open Design
  • Estrusore in vista
  • Carrello X compatibile con tutte le tipologie di estrusori disponibili
  • Area di stampa facilmente accessibile
  • Stampa degli oggetti in vista
  • Assistenza Italiana [email protected]
Immagini Struttura
vista di fronte
vista dall' alto
vista di lato
Dove acquistare
Il modello Galileo è commercializzato dalla Kent's Straper di cui vende sia kit completi,sia versioni già assemblate,sia parti singole;di seguito i link: BLOG
Video Correlati
Presentazione su Rai Tre a Geo Scienza: <videoflash>GSJMYTu1fVs</videoflash>
Buon Natale da tutto il team Kent's Strapper: <videoflash>6bJkaDS_2DM</videoflash>
Alle prese con alcune stampe
<videoflash>0Q-ClmwHfTU</videoflash>
<videoflash>Nd-upXvIbSo</videoflash>
Cosa serve per fare una Galileo
Parti Plastiche
Ecco di seguito due foto delle parti plastiche necessarie per assemblare la GALILEO
Parti Plastiche vista frontale
Parti Plastiche vista laterale
Le parti plastiche si compongono di:
BLOCCO VERDE: Questo blocco comprende le parti che costituiscono la struttura della asse Z
  • 2 x Z Motor Mount
  • 4 x Giunto Motore
BLOCCO BIANCO: Questo blocco comprende le parti che costituiscono la struttura della asse X
  • 4 x Blocca Barra
  • 1 x Supporto Motore XZ
  • 1 x Porta Cuscinetto 608
  • 1 x Supporto XZ
  • 2 x Supporto cuscinetto 608 XZ
BLOCCO ROSSO: Questo blocco comprende le parti che costituiscono la struttura della stampante stessa
  • 2 x Piede
  • 2 x Vertice Basso
  • 2 x Vertice Alto
  • 2 x Bushing
  • 1 x Carrello X
  • 4 x Barclamp
  • 4 x Beltclamp
  • 2 x Puleggie T5 8 denti
  • 1 x Supporto Motore Y
  • 3 x Endstop
Meccanica
Barre Filettate :
  • 4x M8x300mm
  • 4x M8x420 mm barre
  • 2xM8x335mm
  • 1x M8x470mm
  • 1x M8x50mm threaded
  • 2xM8x160mm
Barre Rettificate:
  • 2x 8mmx440mm barra liscia
  • 2x 8mmx390mm barra liscia
Bulloneria
  • 12 M3x20 bulloni
  • 3 M3 x 15 bulloni
  • 70 dadi M8
  • 8 rondelle M8
  • 3 Rondelle Maggiorate
  • 4 x M3 x 40 bulloni
  • 4 Molle M3
  • 32 rondelle M3
  • 32 dadi M3
  • 9 x M3x25 bulloni
  • 2x M3x 30 bulloni
  • 11 x M3 x 10
  • 6xM4 dadi
  • 4xM4 x 20 testa esagono bulloni
  • 2xM4 x 20 testa a brugola bulloni
  • 2 x grani M3 x 10
Cinghie
  • 1x 840mmx5mm T5 pitch timing cinghia -misure standard prusa mendel-
  • 1x 1380mmx5mm T5 pitch timing cinghia -misure standard prusa mendel-
Cuscinetti a sfera
  • 4 x 608 ZZ cuscinetti a sfera
Assemblare Galileo
Strumenti
  • Chiavi inglesi o chiavi di passo vario, per dadi/bulloni da M3 a M8
  • Metro
  • Squadra
  • Brugole varie
  • Pinze
  • Colla a caldo
Introduzione:
Il seguente manuale è rivolto a coloro che si apprestano ad assemblare la reprap Galileo.Tutto il manuale è in lingua italiana,vi sono istruzioni messe per iscritto e video tutorial. Augurandovi un buon montaggio, vi diamo il benvenuto nel mondo della stampa 3d opensource Team Kent’s Strapper
Parte I
MONTARE LA STRUTTURA DI BASE
Componenti Necessari
  • 2 x 420mm barra filettata
  • 12 x dadi M8
  • 2 x Piede
  • 2 x vertice basso
  • 2 x supporto cuscinetto XZ
1. Si prenda una delle quattro barre filettate da 420mm e si avvitino due dadi come in figura, uno verso la fine e uno verso la metà della barra stessa
passo 1
2. Si prenda ora il pezzo plastico Supporto cuscinetto 608 XZ e si faccia passare la barra filettata nel foro orizzontale del pezzo stesso orientandolo come in figura
passo 2
3. Seguendo la figura si faccia scorrere il pezzo plastico fino al dado M8 posto a metà della barra e si avviti un altro dado M8 per serrare il pezzo plastico, non importa serrarlo definitivamente poiché successivamente andrà orientato .Infine si prenda un altro dado M8 e si avviti verso l’inizio della barra come in figura
passo 3
4. Si prenda ora il pezzo plastico Piede e orientandolo come in figura-la barra deve passare per il foro orizzontale del pezzo plastico stesso-si infili nella barra filettata dalla parte iniziale
passo 4
5. Si prenda un dado M8 per serrare il pezzo plastico sulla barra
passo 5
6. Si prenda ora il pezzo plastico Vertice Basso e orientandolo come in figura si faccia passare la barra filettata nel foro orizzontale del pezzo stesso
passo 6
7. Si prenda un dado M8 per serrare il pezzo plastico sulla barra stessa come in figura
passo 7
8. A questo punto se avete seguito le istruzioni avrete ottenuto una st ruttura uguale alla figura seguente, con il pezzo plastico Supporto cuscinetto 608 XZ rivolto verso sinistra
passo 8
9. Occorre ripetere l’intera operazione per realizzare un'altra struttura uguale ma con il pezzo plastico Supporto cuscinetto 608 XZ rivolto verso destra come nella figura che segue
passo 9
Avrete pertanto due strutture uguali alle figure indicate:
passo 9
passo 8
Parte II
ASSEMBLARE LE BARRE FRONTALI
  • ATTENZIONE!!A partire da dicembre 2011 sono stati sotituiti tutti i bulloni M3 x 15 con i bulloni M3 x 20 ad eccezione dei tre bulloni M3 x 15 che fermano il motore sul supporto motore Y
  • 1 x 608 ZZ cuscinetto a Sfera
  • 2 x Rondelle Maggiorate M8
  • 2 x Rondelle M8
  • 2 x 335 mm barre filettate M8
  • 10x Dadi M8
  • 4 x Bar Clamp
<videoflash>emRzuMLCrHs</videoflash>
Parte III
ASSEMBLARE LE BARRE RETTIFICATE
  • 2 x 390 barre rettificate M8
  • Chiave di passo 13
  • Metro
  • Squadra
<videoflash>BYLzb_nEJ3s</videoflash>
Parte IV
ASSEMBLARE IL PIATTO Y -PARTE 1-
  • 4 x Bushing
  • Piatto di stampa 225x225mm o 225x140mm
  • Squadra
  • Metro
  • Colla a caldo
  • Lima rotonda-opzionale-
<videoflash>N6fomGXlFfE</videoflash>
Parte V
ASSEMBLARE IL PIATTO Y -PARTE 2-
  • 1 x Cinghia T5 840mm
  • 1 x Puleggia T5 8 denti
  • 1 x Motore Stepper
  • 3 x bulloni M3 x 15
  • 2 x Belt Clamp
  • 4 x bulloni M3 x 20
  • Brugola
<videoflash>28ufnD7Tqmk</videoflash>
Parte VI
ASSEMBLARE IL PIATTO DI STAMPA
  • 1 x piatto di stampa 250x250mm
  • 4 x Molle M3
  • 4 x bulloni M3 x 40mm
  • 8 x dadi M3
  • 8 x rondelle M3
1.Si prenda il piatto di stampa 250x250mm
punto 1
2.Si prendano 4 bulloni M3 x 40mm e si infilino 4 rondelle M3
punto 2
3.Posiziona ciascun bullone nei fori nel piano.
punto 3
4.Posiziona una rondella, una molla e un altra rondella M3 come in figura;ripetere l'operazione per tutti e 4 i bulloni
punto 4
5.Posiziona sotto ciascun bullone un dado a tenere la molla
punto 5
6.Posiziona il piano 250x250 sopra il piano 225x140 o 225x225mm cosi da far infilare i bulloni nei fori del piano
punto 6
7.Posiziona un dado M3 sotto ciascun bullone a serrare i due piani insieme.
punto 7
8.Usando una livella , posiziona correttamente il piano, stringendo o meno i 4 bulloni montati precendemente
Parte VII
Componenti Necessari:
  • 2 x 420 mm barre filettate M8
  • 2 x 300 mm barre filettate M8
  • 20 x dadi M8
  • 2 x Vertice Alto
  • 2 x Z motor mount
  • 2 x 160mm barre filettate M8
  • 1 x mm barra filettata M8
<videoflash>tnZfRlqPj50</videoflash>
Parte VIII
  • Metro
  • 2 x 300mm barra filettata M8
  • 1 x Supporto XZ
  • 2 x Motori Stepper collegati insieme
  • 4 x dadi M8
  • 4 x giunto motore
  • 8 x bulloni M3 x 20mm
  • 16 x rondelle M3
  • 8 x dadi M3
<videoflash>GGhfsZcFYVk</videoflash>
Parte IX
  • 2 x 420mm barre rettificate M8
  • 4 x Blocca barra
  • 6 x Bulloni M3 x 25mm
  • 2 x Bulloni M3 x 30mm
  • 8 x dadi M3
  • 1 x Carrello X
<videoflash>-HNoguDxHDk</videoflash>
Parte X
<videoflash>VnOy1FUobKc</videoflash>
Parte XI
<videoflash>2vz7NcsEiEU</videoflash>
Collegamenti elettrici
I collegamenti elettrici variano a seconda della scheda utilizzata:
Con Generation 7 v1.2 sono i seguenti:
Collegamenti Generation 7 v1.2
Legenda
  • I puntini colorati posti in alto sono relativi al collegamento dei motori alla scheda:
Giallo,Biano,Marrone,Verde
  • I puntini colorati posti a sinistra,zona centrale,sono relativi al collegamento dell' Heater,blocco scaldante e del Termistore,
il colore Bianco contraddistingue i pin del termistore, Il colore Nero contraddistingue i pin dell'
  • i puntini colorati posti in basso identificano i sensori endstop fine corsa,
Giallo, Verde
  • le scritte,da destra a sinistra DTR e GND identificano i pin del modulo FTDI
