G-code
Revision as of 09:17, 16 February 2010 by Adrianbowyer (talk | contribs) (M111)
Introduction
This page describes the G Codes that the RepRap firmware uses, what they mean, and how they work.
The list of what can be done is extensible. But check here first, and add your extension here first before you implement it.
A typical piece of GCode as sent to a RepRap machine might look like this:
N3 T0 *86
N4 G92 E0 *102
N5 G28 *13
N6 G1 F1500.0 *117
N7 G1 X2.0 Y2.0 F3000.0 *71
N8 G1 X3.0 Y3.0 *39
RepRap G Code Fields
This section explains the letter-preceded fields. The numbers in the fields are represented by nnn. Numbers can be integers, or can contain a decimal point, depending on context. For example an X coordinate can be integer (X175) or fractional (X17.62), whereas selecting extruder number 2.76 makes no sense.
Letter Meaning
Tnnn Select tool nnn. In RepRap, tools are extruders
Snnn Command parameter, such as the voltage to send to a motor
Pnnn Command parameter, such as a time in milliseconds
Xnnn An X coordinate, usually to move to
Ynnn A Y coordinate, usually to move to
Znnn A Z coordinate, usually to move to
Innn Parameter - not currently used
Jnnn Parameter - not currently used
Fnnn Feedrate in mm per minute.
Rnnn Parameter - not currently used
Ennn Length of extrudate in mm. This is exactly like X, Y and Z, but for the length of filament to extrude.
Individual commands
Checking
N and *
These are the line number and the checksum. The RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
The checksum, cs, for a GCode, cmd, (including its line number) is computed as follows:
int cs = 0;
for(int i = 0; i < cmd.length(); i++)
   cs = cs ^ cmd.charAt(i);
Buffered G Commands
The RepRap firmware stores these commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
G0
Example: G0 X12
Rapid move. In this case move rapidly to X = 12 mm. In fact, the RepRap firmware uses exactly the same code for rapid as it uses for controlled moves (see below), as - for the RepRap machine - this is just as efficient as not doing so. (The distinction comes from some old machine tools that used to move faster if the axes were not driven in a straight line. For them G0 allowed any movement in space to get to the destination as fast as possible.)
G1
Example: G1 X90.6 Y13.8 E22.4
Controlled move. Go in a straight line from the current (X, Y) point to the point (90.6, 13.8), extruding material as the move happens from the current extruded length to a length of 22.4 mm.
RepRap does subtle things with feedrates. Thus:
G1 F1500
Will set a feedrate of 1500 mm/minute, then do the move described above at that feedrate. But
G1 F1500
G1 X90.6 Y13.8 E22.4 F3000
Will set a feedrate of 1500 mm/minute, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X, Y movement so everything stays synchronized.
RepRap thus treats feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over accelerations and decelerations in a way that ensures that everything moves together and the right volume of material is extruded at all points.
The first example shows how to get a constant-speed movement. The second how to accelerate or decelerate. Thus
G1 F1500
G1 X80 Y20 E36 F1500
Will do the first movement accelerating as before, and the second decelerating from 3000 mm/minute back to 1500 mm/minute.
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G1 to send an E value that is less than the currently extruded length.
G28
Example: G28
Move to the origin. This causes the RepRap machine to move back to its X, Y and Z zero endstops. It does so accelerating, so as to get there fast. But when it arrives it backs off by 1 mm in each direction slowly, then moves back slowly to the stop. This ensures more accurate positioning.
Unbuffered G commands
The following commands are not buffered. When one is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
G4
Example: G4 P200
Dwell, or delay. In this case sit still doing nothing for 200 milliseconds. During delays the state of the machine (for example the temperatures of its extruders) will still be preserved and controlled.
G20
Example: G20
G21
Example: G21
G90
Example: G90
G91
Example: G91
G92
Example: G92 X10 E90
Set the current position to the values specified. This would set the machine's X coordinate to 10, and the extrude coordinate to 90.
Unbuffered M and T commands
M104
Example: M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder).
M105
Example: M105
Request the temperature of the current extruder in degrees Celsius. The temperature is returned to the host computer.
M106
Example: M106
Turn on the cooling fan (if any).
M107
Example: M107
Turn off the cooling fan (if any).
M108
Example: M108 S0.7
Set the power used by the currently selected extruder's stepper motor. Power is regulated using pulse-width modulation (PWM). In the example the PWM duty cycle would be set to 70%. See also M113.
M109
Example: M109 S190
Set the temperature of the current extruder to 190oC and wait for it to reach that value before sending an acknowledgment to the host. In fact the RepRap firmware waits a while after the temperature has been reached for the extruder to stabilise - typically about 40 seconds. This can be changed by a parameter in the firmware configuration file when the firmware is compiled.
M110
Example: N123 M110
M111
Example: M111 S6
#define DEBUG_ECHO (1<<0)
#define DEBUG_INFO (1<<1)
#define DEBUG_ERRORS (1<<2)
M112
Example: M112
Reserved for Immediate Stop. Not yet implemented.
M113
Example: M113
Use the on-board potentiometer on the extruder controller board to set the PWM for the currently-selected extruder's stepper power. See also M108.
M126
Example: M126 P500
M127
Example: M127 P400
T
Example: T1
Select extruder number 1 to build with. Extruder numbering starts at 0.
