G-code
- 1 Introduction
- 2 RepRap G Code Fields
- 3 Comments
- 4 Individual commands
- 4.1 Checking
- 4.2 Buffered G Commands
- 4.3 Unbuffered G commands
- 4.4 Unbuffered M and T commands
- 4.4.1 M0: Stop
- 4.4.2 M17: Enable/Power all stepper motors
- 4.4.3 M18: Disable all stepper motors
- 4.4.4 M20: List SD card
- 4.4.5 M21: Initialise SD card
- 4.4.6 M22: Release SD card
- 4.4.7 M23: Select SD file
- 4.4.8 M24: Start/resume SD print
- 4.4.9 M25: Pause SD print
- 4.4.10 M26: Set SD position
- 4.4.11 M27: Report SD print status
- 4.4.12 M28: Begin write to SD card
- 4.4.13 M29: Stop writing to SD card
- 4.4.14 M40: Eject
- 4.4.15 M41: Loop
- 4.4.16 M42: Stop on material exhausted
- 4.4.17 M43: Stand by on material exhausted
- 4.4.18 M84: Stop idle hold
- 4.4.19 M92: Set axis_steps_per_unit
- 4.4.20 M101 Turn extruder 1 on Forward
- 4.4.21 M102 Turn extruder 1 on Reverse
- 4.4.22 M103 Turn all extruders off
- 4.4.23 M104: Set Extruder Temperature (Fast)
- 4.4.24 M105: Get Extruder Temperature
- 4.4.25 M106: Fan On
- 4.4.26 M107: Fan Off
- 4.4.27 M108: Set Extruder Speed
- 4.4.28 M109: Set Extruder Temperature
- 4.4.29 M110: Set Current Line Number
- 4.4.30 M111: Set Debug Level
- 4.4.31 M112: Emergency Stop
- 4.4.32 M113: Set Extruder PWM
- 4.4.33 M114: Get Current Position
- 4.4.34 M115: Get Firmware Version and Capabilities
- 4.4.35 M116: Wait
- 4.4.36 M117: Get Zero Position
- 4.4.37 M118: Negotiate Features
- 4.4.38 M119: Get Endstop Status
- 4.4.39 M126: Open Valve
- 4.4.40 M127: Close Valve
- 4.4.41 M140: Bed Temperature (Fast)
- 4.4.42 M141: Chamber Temperature (Fast)
- 4.4.43 M142: Holding Pressure
- 4.4.44 M143: Maximum hot-end temperature
- 4.4.45 M160: Number of mixed materials
- 4.4.46 M226: Gcode Initiated Pause
- 4.4.47 M227: Enable Automatic Reverse and Prime
- 4.4.48 M228: Disable Automatic Reverse and Prime
- 4.4.49 M229: Enable Automatic Reverse and Prime
- 4.4.50 M230: Disable / Enable Wait for Temperature Change
- 4.4.51 M240: Start conveyor belt motor
- 4.4.52 M241: Stop conveyor belt motor
- 4.4.53 M245: Start cooler
- 4.4.54 M246: Stop cooler
- 4.4.55 M300: Play beep sound
- 4.4.56 T: Select Tool
- 5 Proposed EEPROM configuration codes
- 6 Replies from the RepRap machine to the host computer
- 7 Proposal for sending multiple lines of G-code
Introduction
This page describes the G Codes that the RepRap firmware uses and how they work.
The list of what can be done is extensible. But check this page first, and add your extension here first before you implement it.
A typical piece of GCode as sent to a RepRap machine might look like this:
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
TO find out which specific gcode/s are implemented in any given firmware, please see the Firmware_features page.
(For the technically minded, the end of line is marked by both a <nl> and a <cr>. If you want to manually enter GCodes in your reprap using the Arduino Serial interface, make sure to select "Both NL & CR" on the bottom of the screen.)
This isn't accurate, firmware accepts single <nl> as well as single <cr>, or combinations thereof. Hosts should accepts all four combinations as well. --Traumflug 09:34, 20 April 2011 (UTC)
This section explains the letter-preceded fields. The numbers in the fields are represented by nnn. Numbers can be integers, or can contain a decimal point, depending on context. For example an X coordinate can be integer (X175) or fractional (X17.62), whereas trying to select extruder number 2.76 would make no sense.
Letter | Meaning |
Gnnn | Standard GCode command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, tools are extruders |
Snnn | Command parameter, such as the voltage to send to a motor |
Pnnn | Command parameter, such as a time in milliseconds |
Xnnn | An X coordinate, usually to move to |
Ynnn | A Y coordinate, usually to move to |
Znnn | A Z coordinate, usually to move to |
Innn | Parameter - not currently used |
Jnnn | Parameter - not currently used |
Fnnn | Feedrate in mm per minute. (Speed of print head movement) |
Rnnn | Parameter - not currently used |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate in mm. This is exactly like X, Y and Z, but for the length of filament to extrude. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Comments
G Code comments:
N3 T0*57 ;This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Will be ignored by RepRap, as will blank lines. But it's better to strip these out in the host computer before the lines are sent. This saves bandwidth.
Individual commands
Checking
N and *
These are the line number and the checksum. The RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
Buffered G Commands
The RepRap firmware stores these commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
G0: Rapid move
Example: G0 X12
In this case move rapidly to X = 12 mm. In fact, the RepRap firmware uses exactly the same code for rapid as it uses for controlled moves (see G1 below), as - for the RepRap machine - this is just as efficient as not doing so. (The distinction comes from some old machine tools that used to move faster if the axes were not driven in a straight line. For them G0 allowed any movement in space to get to the destination as fast as possible.)
G1: Controlled move
Example: G1 X90.6 Y13.8 E22.4
Go in a straight line from the current (X, Y) point to the point (90.6, 13.8), extruding material as the move happens from the current extruded length to a length of 22.4 mm.
RepRap does subtle things with feedrates. Thus:
G1 F1500 G1 X90.6 Y13.8 E22.4
Will set a feedrate of 1500 mm/minute, then do the move described above at that feedrate. But
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000
Will set a feedrate of 1500 mm/minute, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X, Y movement so everything stays synchronized.
RepRap thus treats feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over accelerations and decelerations in a way that ensures that everything moves together and the right volume of material is extruded at all points.
The first example shows how to get a constant-speed movement. The second how to accelerate or decelerate. Thus
G1 F1500 G1 X90.6 Y13.8 E22.4 F3000 G1 X80 Y20 E36 F1500
Will do the first movement accelerating as before, and the second decelerating from 3000 mm/minute back to 1500 mm/minute.
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G1 to send an E value that is less than the currently extruded length.
G28: Move to Origin
Example: G28
This causes the RepRap machine to move back to its X, Y and Z zero endstops. It does so accelerating, so as to get there fast. But when it arrives it backs off by 1 mm in each direction slowly, then moves back slowly to the stop. This ensures more accurate positioning.
If you add coordinates, then just the axes with coordinates specified will be zeroed. Thus
G28 X0 Y72.3
will zero the X and Y axes, but not Z. The actual coordinate values are ignored.
The following commands are not buffered. When one is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
G4: Dwell
Example: G4 P200
G20: Set Units to Inches
Example: G20
G21: Set Units to Millimeters
Example: G21
Example: G90
Example: G91
G92: Set Position
Example: G92 X10 E90
M0: Stop
Example: M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M112.
Example: M17
Example: M18
M20: List SD card
Example: M20
ok Files: {SQUARE.G,SQCOM.G,}
Example: M21
The SD card is initialised. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialised for the other SD functions to work.
Example: M22
M23: Select SD file
Example: M23 filename.gco
Example: M24
M25: Pause SD print
Example: M25
Example: M26
Example: M27
Report SD print status.
Example: M28 filename.gco
Example: M29 filename.gco
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
Example: M42
If your RepRap can detect when its material runs out, this decides the behaviour when that happens. The X and Y axes are zeroed (but not Z), and then the machine shuts all motors and heaters off. You have to press reset to reactivate the machine. In other words, it parks itself and then executes an M0 command (q.v.).
Example: M43
M84: Stop idle hold
Example: M84
Example: M92 X<newsteps> "Sprinter only"
Depreciated. see MCodeReference. Was used by older style DC extruders. See also Bits From Bytes
Example: M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
Example: M105
Request the temperature of the current extruder and the build base in degrees Celsius. The temperatures are returned to the host computer. For example, the line sent to the host in response to this command looks like
ok T:201 B:117
M106: Fan On
Example: M106 S127
Turn on the cooling fan at half speed. Optional parameter 'S' declares the PWM value (0-255)
M107: Fan Off
Example: M107
Turn off the cooling fan (if any).
Sets speed of extruder motor. (Deprecated in current firmware, see M113)
Example: M109 S190
Set the temperature of the current extruder to 190oC and wait for it to reach that value before sending an acknowledgment to the host. In fact the RepRap firmware waits a while after the temperature has been reached for the extruder to stabilise - typically about 40 seconds. This can be changed by a parameter in the firmware configuration file when the firmware is compiled. See also M104 and M116.
Example: N123 M110
Example: M111 S6
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2)
Example: M112
Any moves in progress are immediately terminated, then RepRap shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M0.
Example: M113
M113 S0.7
Example: M114
Example: M115
sample data from firmware:
M116: Wait
Example: M116
Example: M117
Example: M118 P42
Example: M119
Returns the current state of the configured X,Y,Z endstops. Should take into account any 'inverted endstop' settings, so one can confirm that the machine is interpreting the endstops correctly.
M126: Open Valve
Example: M126 P500
M127: Close Valve
Example: M127 P400
Example: M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed).
Example: M141 S30
Example: M142 S1
Example: M143 S275
Example: M160 S4
When N >= 2, then the E field that controls extrusion requires N+1 values separated by spaces after it like this:
M160 S4 G1 X90.6 Y13.8 E22.4 0.1 0.1 0.1 0.7 G1 X70.6 E42.4 0.0 0.0 0.0 1.0 G1 E42.4 1.0 0.0 0.0 0.0
The second line moves straight to the point (90.6, 13.8) extruding 22.4mm of filament. The mix ratio at the end of the move is 0.1:0.1:0.1:0.7.
The third line moves back 20mm in X extruding 20mm of filament. The mix varies linearly from 0.1:0.1:0.1:0.7 to 0:0:0:1 as the move is made.
The fourth line has no physical effect, but sets the mix proportions for the start of the next move to 1:0:0:0.
Example: M226
Initiates a pause in the same way as if the pause button is pressed.
Example: M227 P1600 S1600
P and S are steps.
Example: M228
Example: M229 P1.0 S1.0
P and S are extruder screw rotations.
Example: M230 S1
Example: M240
The conveyor belt allows to start mass production of a part with a reprap
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
Usage: M300 S<frequency Hz> P<duration ms>
Example: M300 S300 P1000
T: Select Tool
Example: T1
Select extruder number 1 to build with. Extruder numbering starts at 0.
xx can be one of:
ok
rs
ok
start
All this means that every line sent by RepRap to the host computer has a two-character prefix (one of ok, rs, !! or //). The machine should never send a line without such a prefix.
Problem to solve
Each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communcations up. This makes operations very slow, as the usual USB-TTL converters and probably also the host's operating system drivers come with substantial latency, often 10 milliseconds.
For more details on this proposal, and some suggested solutions, and comments please see GCODE_buffer_multiline_proposal
